Trololololo
You have options, if you can have volumes shared across the cluster. Caddy2 clustering - Help - Caddy Community (nginx can do the same, but you'll have to make it play nice with certbot)
Trololololo
So here is a rough proof of concept for clustered Let's Encrypt with Traefik in Docker Swarm. Without a shared file system. Without spending €3000.
DO NOT USE THIS FOR WEBSITES WITH SLAs, there are many ways it can break. If the container for example is re-scheduled to a different node, certbot needs to rebuild all certificates, this takes time and may hit limits, rendering services unavailable.
Alternatives
It's probably a lot saver to use a shared file system if you can and are willing to set it up.
Workflow
certbot certonly --non-interactive --keep-until-expiring ...
Own challenge
The own challenge is implemented because routing information may be misconfigured and we don't want to connect to Let's Encrypt every 15 seconds with the same non-working domain, it will reach limits very fast.
Potential To-Dos
Currently the container serves all existing file certificates. Some may be not needed, some may be expired. So it makes sense to combine with the domain list from Traefik, but that may be empty (network trouble) and in no case you want to create an empty dynamic config file, or it may contain non-working domains without cert files. Food for thought.
Traefik configuration
Traefik can use a http provider in static config to poll in interval the dynamic configuration:
providers:
http:
endpoint: "http://traefik_certbot/traefik-certbot.yml"
pollInterval: 15s
pollTimeout: 5s
Traefik dynamic configuration
The certbot container will return the dynamic config with certificates inline:
tls:
options:
default:
minVersion: VersionTLS12
certificates:
# CERT FILE /etc/letsencrypt/live/example.com
- certFile: |-
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
keyFile: |-
-----BEGIN PRIVATE KEY-----
-----END PRIVATE KEY-----
# CERT FILE /etc/letsencrypt/live/www.example.com
- certFile: |-
keyFile: |-
Proof-of-concept shell code
# run within certbot container
apk add curl pcre-tools
WEBROOT=/webroot
echo WEBROOT $WEBROOT
mkdir -p $WEBROOT/.well-known/acme-challenge
echo START WEBSERVER
python -m http.server 80 --directory $WEBROOT &
/bin/sleep 2
while true; do
echo FETCH DOMAINS
DOMAINS=$( \
curl --silent --max-time 5 http://user:pass@traefik:8080/api/http/routers | \
pcregrep -o '(?<=Host\(`).*?(?=`\))' | sort | uniq \
echo FETCH DONE
for NAME in $DOMAINS; do
echo DOMAIN $NAME
FILE=/.well-known/acme-challenge/traefik-certbot-$EPOCHREALTIME
touch $WEBROOT$FILE
curl --silent --max-time 5 http://$NAME$FILE >> /dev/null
ERR=$?
rm $WEBROOT$FILE
if [ $ERR -eq 0 ]; then
echo DOMAIN CHALLENGE OK, RUN CERTBOT
certbot certonly \
--webroot -w $WEBROOT \
--non-interactive \
--agree-tos \
--no-eff-email \
--keep-until-expiring \
-m email@example.com \
--quiet \
--cert-name $NAME \
-d $NAME
if [ $? -eq 0 ]; then
echo CERTBOT OK $NAME
else
echo CERTBOT FAILED $NAME
fi
else
echo DOMAIN CHALLENGE FAILED http://$NAME$FILE
fi
done
echo TRAEFIK TLS FILE GENERATION
FILE=$WEBROOT/traefik-certbot.yml
printf "tls:\n options:\n default:\n minVersion: VersionTLS12\n certificates:\n" > $FILE
for NAME in $(find /etc/letsencrypt/live/ -maxdepth 1 -mindepth 1 -type d -print) ; do
printf "TRAEFIK TLS FILE ADD $NAME\n"
printf " # CERT FILE $NAME\n" >> $FILE
printf " - certFile: |-\n" >> $FILE
sed -e 's/^/ /' $NAME/fullchain.pem >> $FILE
printf " keyFile: |-\n" >> $FILE
sed -e 's/^/ /' $NAME/privkey.pem >> $FILE
done
#echo TREAFIK TLS FILE CONTENT
#cat $WEBROOT/traefik-certbot.yml
echo SLEEP
/bin/sleep 15
done
Personally I would say this is mandatory for any system using certificates.
Example certbot docker-compose.yml for use with Traefik's provider.http with inline TLS certificates. It will create LetsEncrypt certificates for all Hosts, Traefik will just see them as regular TLS certificate files in dynamic configuration. THIS IS NOT PRODUCTION READY.
version: '3.9'
certbot:
image: certbot/certbot
entrypoint: ["/bin/sh", "-c"]
command:
apk add curl pcre-tools jq
WEBROOT=/webroot
echo WEBROOT $$WEBROOT
mkdir -p $$WEBROOT/.well-known/acme-challenge
python -m http.server 80 --directory $$WEBROOT &
/bin/sleep 2
while true; do
echo FETCH DOMAINS
DOMAINS=$$( \
curl --silent --max-time 5 http://user:pass@traefik_traefik:8080/api/http/routers | \
echo FETCH DONE
for NAME in $$DOMAINS; do
echo DOMAIN $$NAME
FILE=/.well-known/acme-challenge/traefik-certbot-$$EPOCHREALTIME
touch $$WEBROOT$$FILE
curl --silent --max-time 5 http://$$NAME$$FILE >> /dev/null
ERR=$$?
rm $$WEBROOT$$FILE
if [ $$ERR -eq 0 ]; then
certbot certonly \
--webroot -w $$WEBROOT \
--non-interactive \
--agree-tos \
--no-eff-email \
--quiet \
--cert-name $$NAME \
-d $$NAME
if [ $$? -eq 0 ]; then
echo CERTBOT OK $$NAME
else
echo CERTBOT FAILED $$NAME
fi
else
echo DOMAIN CHALLENGE FAILED http://$$NAME$$FILE
fi
done
FILE=$$WEBROOT/traefik-certbot.yml
printf "tls:\n options:\n default:\n minVersion: VersionTLS12\n certificates:\n" > $$FILE
for NAME in $$(find /etc/letsencrypt/live/ -maxdepth 1 -mindepth 1 -type d -print) ; do
echo TRAEFIK TLS FILE ADD $$NAME
printf " # CERT FILE $$NAME\n" >> $$FILE
printf " - certFile: |-\n" >> $$FILE
sed -e 's/^/ /' $$NAME/fullchain.pem >> $$FILE
printf " keyFile: |-\n" >> $$FILE
sed -e 's/^/ /' $$NAME/privkey.pem >> $$FILE
done
#cat $$WEBROOT/traefik-certbot.yml
echo SLEEP
/bin/sleep 15
done
hostname: '{{.Node.Hostname}}'
networks:
- proxy
volumes:
- traefik-certificates:/etc/letsencrypt
deploy:
replicas: 1 # only single instance
placement:
constraints:
- node.role==manager # for service discovery
labels:
- 'traefik.enable=true'
- 'traefik.http.routers.certbot.entrypoints=web'
- 'traefik.http.routers.certbot.rule=PathPrefix(`/.well-known/acme-challenge`)'
- 'traefik.http.routers.certbot.priority=1024'
- 'traefik.http.services.certbot.loadbalancer.server.port=80'
Pieces of the Traefik static configuration:
providers:
docker:
endpoint: "unix:///var/run/docker.sock"
swarmMode: true
exposedByDefault: false
network: proxy
# for dashboard
file:
filename: /traefik-dynamic.yml
watch: true
# for LetsEncrypt certificates from certbot
http:
pollInterval: 15s
pollTimeout: 5s
entryPoints:
web:
address: :80
http:
redirections:
entryPoint:
to: websecure
scheme: https
priority: 1000 # needed for certbot to be able to overrule
websecure:
It's probably better to use a shared folder across all Traefik nodes and write the dynamic config file into the folder and use Traefik with watching provider.file instead. Then you could just copy and reference the certificates instead of inlining them. Be aware that the host folder needs to exist when running with Docker Swarm.
