My domain is:paksociety.com
My operating system is Centos 7
My web server is Apache-Nginx
I can login to a root shell on my machine YES
I’m using a control panel to manage my site :Direct Admin
As i am using Direct admin so i have plugin to install SSL from lets encrypt, previously i was using PLESK and everthing was fine, now i am using one domain and one subdomain , both were added as domain, as i want to use domain pointers for both of them as aliases, however i came to know that if i install SSL on such 2 domains only one will work, in start i was thinking it is a dns issue as i recently changed server, but after digging i found out that i was wrong, and it is directadmin problem, and as i was in panic so i request for ssl certificate from lets encrypt three to four times for main domain as subdomain was working fine,
Now as there is limit of 20 ssls per week, i want to know how much ssl i can generate in this week?? as now i will add subdomian in the panel of main domain , and total 8 domain names will be added in SSL, one main and 7 subdomains. is there any way to check remaining attempts? or can i request to increase limit so that i can use valid https in this week too??
Best Regards
