so i re-added agree-dev-preview (just for grins) but gave it an arbitrary value and now received this:
Use of --agree-dev-preview is deprecated.
followed by my errant value: letsencrypt: error: unrecognized arguments: Y
but still doesn’t work.
i user centos 7 in case that matters…
Yeah i test both both CentOS 7.1 via default python 2.7 system and CentOS 6.7 via IUS Community repo’s python 2.7.10 side install
i see the same error even when running a basic command such as
./letsencrypt-auto --help webroot
i use letsencrypt
command not letsencrypt-auto
/root/.local/share/letsencrypt/bin/letsencrypt --version
letsencrypt 0.1.0
no problems
/root/.local/share/letsencrypt/bin/letsencrypt --help webroot
usage:
letsencrypt [SUBCOMMAND] [options] [-d domain] [-d domain] …
The Let’s Encrypt agent can obtain and install HTTPS/TLS/SSL certificates. By
default, it will attempt to use a webserver both for obtaining and installing
the cert. Major SUBCOMMANDS are:
(default) run Obtain & install a cert in your current webserver
certonly Obtain cert, but do not install it (aka “auth”)
install Install a previously obtained cert in a server
revoke Revoke a previously obtained certificate
rollback Rollback server configuration changes made during install
config_changes Show changes made to server config during installation
plugins Display information about installed plugins
optional arguments:
-h, --help show this help message and exit
-c CONFIG_FILE, --config CONFIG_FILE
config file path (default: None)
webroot:
Webroot Authenticator
-w WEBROOT_PATH, --webroot-path WEBROOT_PATH
public_html / webroot path. This can be specified
multiple times to handle different domains; each
domain will have the webroot path that preceded it.
For instance:-w /var/www/example -d example.com -d www.example.com -w /var/www/thing -d thing.net -d m.thing.net
(default: None)
nope; same error. in fact, even the version command produces said error.
maybe reinstall the client
already done; and by that i mean i moved my /letsencrypt folder elsewhere and re-pulled from git. any other steps needed?
I just tried requesting a brand new cert with an original domain with no luck; i received the same error. has no one else really seen this using centos 7 and webroot auth with nginx?
now i can’t request addt’l new certs anymore…
There is a project out there called Caddy which automatically integrates LE and i tested that; works fine with a new unique cert / domain request.
strange having no problems with my Centmin Mod LEMP Nginx stack with CentOS 6.7 or 7.1 uses webroot too Letsencrypt Free SSL Certificates
have you tried without a .ini file passed on cmd line and just doing full webroot commands too ? maybe it's some formatting issue in your .ini file ?
yes i tried with cmd line only; no joy.
Now I’m really confused; I just tried again with a new domain and this time strictly followed the Beta invite’s email instructions (with letsencrypt-auto):
/root/.local/share/letsencrypt/bin/letsencrypt certonly -a webroot --webroot-path /usr/lib/mailman -d lists.garbage-juice.com --server https://acme-v01.api.letsencrypt.org/directory --agree-dev-preview
and while it did warn me of the deprecation of the agree-dev-preview command, it worked, for the new cert.
Now I just tried renewing the same cert i just received, this time adding --renew-by-default, and it also now worked fine, while still warning me of the deprecated command.
So now I went back to one of my original domains (one cert, 2 domains) I had been trying to renew for days now (as a test), and SOB, it appears to possibly have worked except i got rateLimited (probably due to my testing).
So IDK what’s up but it works now seemingly. WTF!? haha…
weird you sure previously you used bin/letsencrypt
and not bin/letsencrypt-auto
when running webroot command ?
i actually have always been using (including now with my success):
/letsencrypt/letsencrypt-auto …
i see i ask as i always use bin/letsencrypt
with webroot without issues
I had the idea to run the webroot thing via a crontab. Problem is that everytime I do that manually the script requires me to confirm that I want to replace existing certificates for the given domain(s). Won’t that be an issue with crontab-running?
I actually didn’t, neither did I find it in the docs nor via the --help flag. What exactly does that flag do?
EDIT: I just ran the command with that flag in addition and it didn’t prompt me for confirmation - nice, thanks! Is that the (only) thing the flag does?
You should see all available parameters using letsencrypt-auto --help all
. If you can’t see that parameter maybe is because letsencrypt is outdated. To update it, if you used git clone letsencrypt
just go to the same dir where you have letsencrypt-auto
command and use git pull
command to update it.
Regarding --renew-by-default
parameter, yes, as far as I know that is all that it does, renew your certificate without asking questions:
--renew-by-default Select renewal by default when domains are a superset
of a a previously attained cert (default: False)
