How make crt for Exchange?
Hellow, pls, tell me, how i can make cetificate for Exchange ? pfx file with double name - mail and autodiscover.
Which version of Windows Server and which version of Exchange are you using? That may be important for the community to know in order to help with your question. Thanks!
Hellow. Windows Server 2016, Exchange 2016.
Hi @Andrei9385
first start with some basics:
Then check the long list of client implementations.
There are a lot of Windows clients. But what’s the best? I don’t know.
If the client creates only pem files, that’s not a problem. You can use other tools to create a pfx file.
