How do I solve to many requests
My domain is: ech2.synology.me
My web server is (include version): Synology MAS 720+
The operating system my web server runs on is (include version):DSM 7
Goodday,
I am new at this forum so I hope I am following the correct route.
I have a Synology NAS 720+ running DSM 7. I have installed Plex Media Server but it has an issue with the safe connection. In order to deal with that I took a Let's Encrypt cert for ech2.synology.me (a DDNS issued bij Synology). I kept having problems contecting to my Plex Server (unsafe connection) so I threw out the Lets Encrypt cert to try and use another. Because I began having other problems, I wanted to reinstall the cert for ech2.synology.me. However, and this is my problem, Let's Encrypt now returns the answer that I applied to often !! What can I do??
Thanks for your help. Kind regards, Rob
Hi @rvldj and welcome to the LE community forum :slight_smile:
You can solve the problem by ensuring LE can reach your Synology device via IPv6.
Note: LE prefers IPv6 when present.
Addresses: 2a02:a44a:4ca5:1:211:32ff:fedb:fcfb
           80.61.229.120
OR remove the IPv6 address from DNS.
See how they don't return the exact same thing:
curl -Ii6 http://ech2.synology.me/
HTTP/1.1 200 OK
Server: nginx
Date: Thu, 11 Nov 2021 12:29:54 GMT
Content-Type: text/html
Content-Length: 1991
Keep-Alive: timeout=20
Vary: Accept-Encoding
Last-Modified: Tue, 12 Oct 2021 08:43:34 GMT
ETag: "61654ab6-7c7"
Accept-Ranges: bytes
curl -Ii4 http://ech2.synology.me/
HTTP/1.1 403 Forbidden
Date: Thu, 11 Nov 2021 12:29:58 GMT
Content-Length: 3322
Last-Modified: Wed, 17 Mar 2021 11:02:44 GMT
ETag: "cfa-5bdb96c1d1d00"
That was quick !! :slight_smile: Thanks for your reply. I will try your suggestions.
I appologize for any inconvenience. I am new at this particular subject.
I wanted to put 2a02:a44a:4ca5:1:211:32ff:fedb:fcfb as IPv6 address but the router (Fritzbox 7590) refused the address.
There is a IPv6 address provided by my provider. So, IPv6 is enabled.
I tried to make a new certificate but keeps saying: The maximum number of certificate request for this domain-name has been reached
Welcome to the Let's Encrypt Community, Rob :slightly_smiling_face:
You have certainly not had any trouble acquiring Let's Encrypt certificates as you are running into the duplicate certificate rate limit.
certificate history of ech2.synology.me:
https://crt.sh/?q=ech2.synology.me
You simply need to install one of the five certificates you have already generated in the last 24 hours.
Hi Griffin,
Thank you very much for your help. How do I download the certificate?
kind regards,
Rob
Certificates are public information.
But they are useless without the matching private key.
So, your first hurdle is ensuring it still has the private key for the last cert issued.
If it does, then you can find the public cert from the link @griffin provided:
