miatvc.ca
miniserv.pl
Ubuntu 21.10 (impish)
webmin/usermin
certbot 1.12.0
I tested it with ssl labs and it says it is not trusted for providing another certificate (eagleoneonline.ca) which is another domain I own. Why is it always generating a second cert within
I had to recreate the letsencrypt certificate using the webmin certbot plugin. I then told webmin to copy the cert to the usermin config file.
I recreated the cert for the other domain eagleononline.ca. Webmin copied that cert, key and ca into it's own config file, overwriting the proper one. I'll be contacting the author of webmin.
