thekidslepthere.com
Ubuntu 20.04
no
or certbot-auto --version
if you're using Certbot):
1.27.0
I'm using passenger-nginx-module It's nginx but it installs the nginx binary in the folder /opt/nginx/sbin I could have chosen any folder but I don't think I could have used /usr/bin or /usr/sbin because it would obscure the system and the passenger versions and would just be bad convention
When I run the command:
sudo certbot nginx
I get the following error:
The nginx plugin is not working; there may be problems with your existing configuration.
The error was: NoInstallationError("Could not find a usable 'nginx' binary. Ensure nginx exists, the binary is executable, and your PATH is set correctly.")
