I'm using built in generator in a ISP6. IP 91.210.171.213
error in log: Type: 'rpc' Object: 'query' Value: 'query: SSL connect error'
url: https://acme-v02.api.letsencrypt.org/acme/acct/354109220
My domain is: kriptoplan.ru
I try do
wget https://acme-v02.api.letsencrypt.org/acme/acct/354109220
from server - I get:
Resolving acme-v02.api.letsencrypt.org (acme-v02.api.letsencrypt.org )... 172.65.32.248, 2606:4700:60:0:f53d:5624:85c7:3a2c
Connecting to acme-v02.api.letsencrypt.org (acme-v02.api.letsencrypt.org )|172.65.32.248|:443... connected.
GnuTLS: Error in the pull function.
Unable to establish SSL connection.
Osiris
January 8, 2022, 7:50pm
#2
Usually the client would report a "handshake error" if there is a problem with blocks due to DDoS prevention. However, I'm not sure how GnuTLS would report such a thing.
Let's just ask the professionals at @lestaff
Hi, @dellmaster ,
We're not blocking or rate limiting your IP addresses, but your report looks like it's related to this problem that we're investigating: API service disruption for Russian subscribers
Hi, @dellmaster ,
Could you please show us the output of a traceroute to acme-v02.api.letsencrypt.org
? Feel free to either post it here or send it to me as a direct message.
msncom
January 9, 2022, 12:21pm
#5
Hi, @JamesLE
(Russian server)
traceroute to acme-v02.api.letsencrypt.org (172.65.32.248), 30 hops max, 60 byte packets
1 185.4.67.253 (185.4.67.253) 1.005 ms 1.029 ms 1.219 ms
2 195.209.62.67 (195.209.62.67) 0.486 ms J1-SLV-MG1.net.reconn.ru (195.209.63.101) 0.499 ms 195.209.62.7
7 (195.209.62.77) 0.487 ms
3 109.239.135.58 (109.239.135.58) 0.892 ms 31.28.19.100 (31.28.19.100) 0.501 ms 6.203 ms
4 10.10.13.153 (10.10.13.153) 18.058 ms 18.065 ms 7.829 ms
5 109.239.136.210 (109.239.136.210) 7.447 ms 7.427 ms spx-ix.as13335.net (194.226.100.129) 8.554 ms
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
1 vds-cp76619.timeweb.ru (2.59.40.1) 0.947 ms 0.976 ms 0.962 ms
2 172.17.1.1 (172.17.1.1) 12.009 ms 12.182 ms 12.186 ms
3 spx-ix.as13335.net (194.226.100.129) 1.475 ms 1.394 ms 1.436 ms
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
We believe the network routing problem from the St. Petersburg, Russia region is now resolved. If you're still having trouble, please let us know. Thanks for your patience!
Hi, troble still exists.
1 77-222-55-253.vps-ptr.clients.spaceweb.ru (77.222.55.253) 16.571 ms 16.542 ms 16.592 ms
2 spb-sdn-nr1.nic.ru (31.177.85.164) 0.940 ms 3.051 ms 3.036 ms
3 213.59.214.153 (213.59.214.153) 8.735 ms 8.721 ms 8.700 ms
4 87.226.181.85 (87.226.181.85) 13.850 ms 87.226.183.85 (87.226.183.85) 13.000 ms *
5 95.71.2.226 (95.71.2.226) 14.029 ms 24.882 ms 65.900 ms
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
system
closed
February 9, 2022, 11:21am
#10
