Hopelessly lost, SSL cert missing after years of renewals
After years of renewing my certs I now have issues. It’s been so long since I’ve had any issues with this server I’m rusty and have tried so many things I have totally confused myself. Please, will someone help walk me thru renewing my certs for devrod.com with several subs. I think I have around 10 days before expiration.
To confirm; the fullchain.pem is missing, I don’t know why or how to fix it.
My domain is: devrod.com
web server: Apache.2.1.9
OS: Ubuntu 18.04
My hosting provider; Self
sudo certbot renew
Output:
No renewals were attempted.
ran command:
sudo certbot
Output:
Error while running apache2ctl configtest.
Action ‘configtest’ failed.
AH00526: Syntax error on line 38 of /etc/apache2/sites-enabled/000-default-le-ssl.conf:
SSLCertificateFile: file ‘/etc/letsencrypt/live/devrod.com/fullchain.pem’ does not exist or is empty
Devrod
sudo certbot certificates
Results
No certs found.
Seems that somebody has deleted your certificate from your Certbot installation (or the deleted /etc/letsencrypt directory). If you didn’t do it, I don’t know it could have happened.
You will need to first get your Apache configuration functional. It currently references a certificate that does not exist - you will not be able to restart Apache until that’s fixed. Either comment out that SSL virtual host by hand, or maybe try:
sudo a2dissite 000-default-le-ssl
Once that’s done, you can try get the certificate created again:
sudo certbot --apache
OK, I’ll do the “a2dissite 000-default-le-ssl”
Will I nee to do that for the Sub-Domains also?
The goal is to get to a point where this doesn’t produce any errors:
sudo apachectl configtest
We know for sure that the one site for sure needs to be disabled, and then you can check again. Rinse and repeat until it works.
Hi @devrod
checking your domain there is a working Apache - https://check-your-website.server-daten.de/?q=devrod.com
But it's http over port 443, Grade Q.
http://devrod.com/ 72.179.58.107 301 https://devrod.com/ Html is minified: 100,00 % 0.354 A
http://www.devrod.com/ 72.179.58.107 301 https://www.devrod.com/ Html is minified: 100,00 % 0.434 A
https://devrod.com/ 72.179.58.107 -4 0.627 W
SendFailure - The underlying connection was closed: An unexpected error occurred on a send.
https://www.devrod.com/ 72.179.58.107 -4 0.623 W
http://devrod.com:443/ 72.179.58.107 GZip used - 4399 / 13557 - 67,55 % 200 Html is minified: 140,27 % 0.330 Q
http + 443 sends a correct http answer, https + 443 sends the typical answer
SSL_ERROR_RX_RECORD_TOO_LONG
http + port 80 + /.well-known/acme-challenge/random-filename has a wrong redirect http -> https. That requires a working port 443, but your port 443 doesn't work.
May be certbot --apache works, perhaps remove that redirect.
Run apachectl -S as root or sudo.
PS: 20 Minutes later, now there is a working new Letsencrypt certificate
https://devrod.com/
:+1:
Yes Sir, You caught me with my pants down. I believe they’re back up now.
Thanks for Run response, it helped
Thanks, you were a great help after knocking off some rust things started to make sense. I really appreciate it.
Again Thanks!
