Now it working. To resume: the $LE_Domain was not working so instead on the script I have put
domain=$(basename $(pwd))
and now everything is working.
Thank you all
Thank you all
To recap:
I have used this script in /usr/local/bin/hitch-renew-hook
#!/bin/bash
# Full path to pre-generated Diffie Hellman Parameters file
dhparams=/etc/hitch/dhparams.pem
acmehome=/root/.acme.sh
set noglob
umask 077
cat "${acmehome}/${domain}/${domain}.key" \
"${acmehome}/${domain}/fullchain.cer" \
"${dhparams}" > "${acmehome}/${domain}/hitch-bundle.pem"
then you have to do this command (assuming you use dynu.com as your dns provider):
acme.sh --issue -d domain.com -d '*.mydomain.com' --dns dns_dynu --renew-hook '/usr/local/bin/hitch-renew-hook' --post-hook 'systemctl reload hitch'
and then, the first time you issue a certificate you have to run this command:
acme.sh --renew --force -d mydomain.com -d '*.mydomain.com'
You are all set to use hitch with letsencrypt. See more at: https://docs.varnish-software.com/tutorials/hitch-letsencrypt/
