On my own Server here, Apache 2.4, Virtual Hosts. Mac HighSierra.
Apache configured and working fine. Homebrew installed and working for other stuff as well.
Did the lets get a cert without messing with the configs thing and straight up got this.
$ sudo certbot --apache certonly
Could not choose appropriate plugin: The apache plugin is not working; there may be problems with your existing configuration.
The error was: PluginError(‘There has been an error in parsing the file /etc/apache2/httpd.conf on line 697: Syntax error’,)
certbot is apparently installed.
$sudo certbot certonly returns almost the whole deal, but times out. Filling out the command line options as requested by prompts.
then
Waiting for verification…
Failed authorization procedure. robert-chalmers.uk (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://robert-chalmers.uk/.well-known/acme- challenge/Bs__JuQjUT7cE_UH6dn6YSlC2Iv3LfhVDi5jRIsSfRI: Timeout, quantum-radio.net (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://quantum- radio.net/.well-known/acme-challenge/Is-Eua2IP1dHYqVZhfX21G6iCg_mrXTb344pXx82bns: Timeout, robert- chalmers.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://robert-chalmers.uk/.well-known/acme-challenge/2L8MajWihFFNBw_Q0hZnnjkgDIJQ0On2lxhbQVfIHhY: Timeout
Domain: robert-chalmers.uk
Type: connection
Detail: Fetching
http://robert-chalmers.uk/.well-known/acme-challenge/Bs__JuQjUT7cE_UH6dn6YSlC2Iv3LfhVDi5jRIsSfRI:
Timeout
Domain: quantum-radio.net
Type: connection
Detail: Fetching
http://quantum-radio.net/.well-known/acme-challenge/Is-Eua2IP1dHYqVZhfX21G6iCg_mrXTb344pXx82bns:
Timeout
Domain: robert-chalmers.com
Type: connection
Detail: Fetching
Timeout
