My ssl was blocked, I was having a cloudflare problem and I generated the ssl let's 5 times and it blocked me how can I solve this problem.
on siteground.
" No se ha podido instalar Let's Encrypt para otakulive.net .
Yes, I see you are getting a HTTP 526 error from Cloudflare. This means the cert on your origin server is not correct for your Cloudflare SSL setting (strict).
You might want to consider using the Cloudflare Origin CA Cert instead. Then you would not need to use Let's Encrypt. The topic below describes the 526 and has a link for using the Origin cert.
