Please I need help for this issue. Trying for 2 days but cant solve the issue.
My domain is: theshadowmedia.com
1: theshadowmedia.com
2: www.theshadowmedia.com
Requesting a certificate for theshadowmedia.com and www.theshadowmedia.com
Domain: www.theshadowmedia.com
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for www.theshadowmedia.com - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for www.theshadowmedia.com - check that a DNS record exists for this domain
My hosting provider, if applicable, is: digitalocean
or certbot-auto --version
if you're using Certbot):
