I am currently using a certificate issued by Let's Encrypt for my RabbitMQ server. However, I am having trouble configuring the SSL setup because I need to generate the full-chain certificate to use with RabbitMQ.
Could you please guide me on how to create a full-chain certificate from the files I have received? Specifically, I need to know how to combine the certificate with the intermediate and root certificates to generate the full-chain that RabbitMQ can use.
The "full chain" file you describe is the collection of trusted CA root certificates on your system. They are not related to the cert file you received from Let's Encrypt.
What those are, exactly, varies depending on your o/s and other system settings.
We don't see RabbitMQ much on this forum. This seems like a question better directed at a RabbitMQ forum or their github.
Perhaps someone else here will be familiar with that and offer help. While we often help configure common servers on commonly used operating systems we do not focus on providing help for every possible TLS situation.
That said, for anyone to help you we would need the answers to the other questions you were shown when posting in the Help topic. Especially the section about your o/s and its version and the ACME Client you used and its version. See original form below
A link to the instructions you are following for configuring RabbitMQ would be helpful too. I quickly reviewed their site and there are many places that talk about this configuration.
Please also clarify if you are trying to setup mTLS or just TLS
How did you get those files? I.e., which ACME client did you use?
Also, the documentation at TLS Support | RabbitMQ is highly confusing and, IMO, not well structured. I have absolutely no clue what the purpose of ssl_options.cacertfile is: is it just for client authentication or does RabbitMQ somehow use the CA cert (bundle) to validate the configured server certificate chain? Or does it use that option for the chain? Including the roo? Excluding the root? So many questions...
And another question: do you actually need your RabbitMQ server to be TLS encrypted? I.e.: are you using it over the public internet? Because if it's just internal on a secure network, why bother?
I wanted to use the files generated by win-acme for RabbitMQ to enable SSL. However, after using the key, chain-only, and cert files in the following configuration, SSL is still not working for RabbitMQ:
In addition to that you should probably put quotes around the path. You have imbedded spaces and usually quotes are needed for that. Maybe RabbitMQ parses it without but it is something to try.
If you want more help from us please describe the details of what you mean by this
