My domain is: sfcfloors.com
I ran this command: certifytheweb
2019-01-08 15:32:41.096 -05:00 [INF] SFC-AFP01: Request failed - Can not finalize order with status βValidβ. Certes.AcmeException: Can not finalize order with status βValidβ.
at Certes.IOrderContextExtensions.d__2.MoveNext()
β End of stack trace from previous location where exception was thrown β
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at Certify.Providers.Certes.CertesACMEProvider.d__30.MoveNext()
at Certify.Management.CertifyManager.d__11.MoveNext() in C:\Work\GIT\certify\src\Certify.Core\Management\CertifyManager\CertifyManager.CertificateRequest.cs:line 704
at Certify.Management.CertifyManager.d__10.MoveNext() in C:\Work\GIT\certify\src\Certify.Core\Management\CertifyManager\CertifyManager.CertificateRequest.cs:line 518
at Certify.Management.CertifyManager.d__7.MoveNext() in C:\Work\GIT\certify\src\Certify.Core\Management\CertifyManager\CertifyManager.CertificateRequest.cs:line 303
2019-01-08 15:32:41.097 -05:00 [INF] SFC-AFP01: Request failed - Can not finalize order with status βValidβ. Certes.AcmeException: Can not finalize order with status βValidβ.
2019-01-08 15:32:41.937 -05:00 [ERR] Certificate request process failed: Certes.AcmeException: Can not finalize order with status βValidβ.
2019-01-08 15:32:57.054 -05:00 [INF] Post-Request Script output:
Invoke-Command: Object reference not set to an instance of an object.
At C:\Windows\system32\WindowsPowerShell\v1.0\Modules\RemoteDesktop\Certificate.psm1:375 char:5
Invoke-Command -Session $M3PSession -ArgumentList @($params)`
Set-RDRDCertificate: Deployment does not contain an RD Gateway server.
At C:\Program Files\CertifyTheWeb\Scripts\Common\rdscerts-install.ps1:7 char:4
- Set-RDCertificate -Role RDGateway -ImportPath $pfxpath -Force
2019-01-08 15:33:10.756 -05:00 [INF] Post-Request Script output:
iis 10/rds windows
server 2016
I can login to a root shell on my machine (yes or no, or I donβt know):
Iβm using a control panel to manage my site (no, or provide the name and version of the control panel):
