This is normal.
The first should be your public cert.
The second should be the Intermediate cert (in the chain).
Please show this file:
/etc/letsencrypt/archive/vorman.mooo.com/fullchain2.pem
This is normal.
Certificate Name: vorman.mooo.com
Domains: vorman.mooo.com
Expiry Date: 2019-03-08 09:45:51+00:00 (VALID: 66 days)
Certificate Path: /etc/letsencrypt/live/vorman.mooo.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/vorman.mooo.com/privkey.pem
root@vorman:/etc/letsencrypt/archive/vorman.mooo.com# certbot-auto certificates
Found the following certs:
There are your two files. So use these in your config file.
The first is expired, the second looks good.
Please show:
OK then those are the files you should be using.
Sorry, the thread is a little long...
What is the current problem?
Please show:
grep -Eri 'root|cert|name|alias' /etc/lighttpd/
grep -Eri 'root|cert|name|alias' /var/www/
Issue is ssl check shows ssl expired but I renewed
Hi @Soydepr,
Thanks for sharing the configuration that @rg305 asked for above. I suspect that the trouble might relate to
/etc/lighttpd/ssl/vorman.mooo.com.crt:-----BEGIN CERTIFICATE-----
/etc/lighttpd/ssl/vorman.mooo.com.crt:-----END CERTIFICATE-----
/etc/lighttpd/ssl/vorman.mooo.com.pem:-----BEGIN CERTIFICATE-----
/etc/lighttpd/ssl/vorman.mooo.com.pem:-----END CERTIFICATE-----
In this case, it looks like your old certificate and associated files were copied directly into /etc/lighttpd/ssl
, which might be the usual place to store these files with lighttpd. However, the renewal always creates a new certificate, which Certbot ensures is pointed to by the entries within /etc/letsencrypt/live/vorman.mooo.com
. Certbot doesnât copy the new certificate files into /etc/lighttpd/ssl
Do you know how the files that you originally create ended up inside /etc/lighttpd/ssl
? Did you manually copy them there?
Three possible ways of fixing this problem, depending on your preferences:
(1) Change your lighttpd configuration so that it points at /etc/letsencrypt/live
files instead of /etc/lighttpd/ssl
files.
(2) Copy the updated files from /etc/letsencrypt/live
(and ideally write a shell script to do this and then specify that shell script with Certbotâs --deploy-hook
option so that Certbot will know to run it automatically following each renewal event).
(3) Create symlinks in /etc/lighttpd/ssl
(using ln -s
) to the corresponding locations in /etc/letsencrypt/live
so that lighttpd will always find the updated files after a renewal.
Lighttpd wants cert.pem
and privkey.pem
in one file and chain.pem
in a second file.
Probably vorman.mooo.cm.pem
is the former, and vorman.mooo.com.crt
is the latter.
So youâd have to set up a deploy hook to update the files and reload Lighttpd.
Thanks for pointing that out, @mnordhoff. That suggests to me that some tutorial probably gave @Soydepr the commands for creating these files, because Certbot wouldnât have done that itself. In that case, these same commands could be included in a deploy-hook script.
Please clarify not sure I understand what you mean by deploy hook
Can I just copy /letsencrypt/live/vorman.mooo.com/fullchain.pem To
Etc/lighttpd
That is the general idea; just with a script that gets called any time the cert is renewed (--deploy-hook
But I'm not certain where you are actually using the cert...
From your post, only these lines look related but they are rem'd out:
/etc/lighttpd/lighttpd.conf:# server.name = "vorman.mooo.com"
/etc/lighttpd/lighttpd.conf:# server.document-root = "/var/wwww/html/owncloud"
/etc/lighttpd/lighttpd.conf:# ssl.pemfile = "/etc/lighttpd/certs/lighttpd.pem"
So...
Can you also show?:
I think this is the relevant part of my confit file
SERVER[âsocketâ] == â:443â {
ssl.engine = âenableâ
ssl.pemfile = â/etc/letsencrypt/live/vorman.mooo.com/combined.pemâ
ssl.ca-file = â/etc/letsencrypt/live/vorman.mooo.com/fullchain.pemâ
ssl.cipher-list = âECDHE-RSA-AES256-SHA384:AES256-SHA256:HIGH:!MD5:!aNULL:!EDH:!AESGCMâ
ssl.honor-cipher-order = âenableâ
ssl.use-sslv2 = âdisableâ
ssl.use-sslv3 = âdisableâ
root@vorman:/home/pi# grep -Eri âroot|cert|name|aliasâ /var/www/
bash: cert: command not found
bash: aliasâ: command not found
bash: name: command not found> ^C
root@vorman:/home/pi# grep -Eri âvorman.mooo.comâ /var/www
Above command does not finish
Ok then you need to figure out you made the combined.pem
file (or just create a new script to do that again).
Confused âŚ
Please clarify .
This is what I did .
On dec 8 I renewed successfully with help on initial thread
SOmehow ssl check shows my cert expired
Looks more that you have created a certificate, but didn't install it. Because you have to do the installation of your lighttpd manual.
PS: You have to create one file with the private and the public key:
https://ssl-trust.com/ssl-zertifikat-installieren/lighttpd
- Es ist notwendig fĂźr Lighttpd, dass Zertifikat und privater SchlĂźssel in einer Datei vorliegen. Die geschieht durch folgenden Befehl:
cat /etc/ssl.key/example.com.key /etc/ssl.crt/example.com.crt >> /etc/lighttpd/example.com.pem
There is your command. Change the paths, then add the result file to your configuration.
