Help using DNS validatin (acme-dns-certbot)
disregard
Please use the staging environment for testing purposes.
Also, you're using the script available from acme-dns-certbot-joohoi/acme-dns-auth.py at master · joohoi/acme-dns-certbot-joohoi · GitHub right? You do realise that script is to be specifically used with the GitHub - joohoi/acme-dns: Limited DNS server with RESTful HTTP API to handle ACME DNS challenges easily and securely. service? Do you have acme-dns set up properly? The output you're showing now probably isn't the first output.. When the acme-dns-auth.py script is ran for the first time, it told you to add a specific CNAME for your _acme-challenge.cdn.incognet.io DNS resource record. I can't find such a CNAME record. Did you add it, as the script told you?
