Help using a tool to import apache letsencrypt certificates
My domain is: https://macos.retro-os.live
I ran this command: N/A
It produced this output: N/A
My web server is (include version): Apache2
The operating system my web server runs on is (include version): Ubuntu 24.04
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.9.0
I'm trying to use a tool for synchronet bbs software that imports a existing letsencrypt cert into the format synchronet supports. It supports p12 format certs. The docs say to use this command to create the p12 file:
openssl pkcs12 -export -out cert.p12 -in cert.pem -inkey key.pem
Enter Export Password: SYSPASS
Verifying - Enter Export Password: SYSPASS
Can you tell me where the existing apache2 certs are for cert.pem and key.pem?
Thanks!
Certbot places the cert files as described here: User Guide — Certbot 5.8.0.dev0 documentation
I believe you use the fullchain.pem file for the -in file (not cert.pem). The -inkey is the privkey.pem in the Certbot directory
Also, you probably want to make a script that does whatever needs to happen, and then call it from certbot's --deploy-hook, so that it will automatically run whenever you get an updated certificate.
Many thanks!
