Hi, the ip address of our mails erver looks to be blocked, ip address: 51.222.173.52, this is a recently adquired ip address from our dedicated server provider, in a new zimbra installation, thanks in advance
is exactly the same software installed on both, i supsect maybe was something with the ip address of the first one: 51.222.173.52 but now i am figuring out there is one diference on the network configuration, the first one --> 51.222.173.52 traffic pass through an aditional router (without NAT, only routed) and the server have two ip address, i don't know if maybe these is the problem the second one is connected directly. What do you recomend i can configure the first server without the aditional router to check if the problem persist
Thank you for your help, now i was able to generate the certificate
Requesting a certificate for correo.naguanaguadigital.com
http-01 challenge for correo.naguanaguadigital.com
Certificate is saved at: /etc/letsencrypt/live/correo.naguanaguadigital.com/fullchain.pem
Key is saved at: /etc/letsencrypt/live/correo.naguanaguadigital.com/privkey.pem
This certificate expires on 2022-08-02.
Certbot has set up a scheduled task to automatically renew this certificate in the background.
