#user nginx;
worker_processes 1;
#error_log /var/log/nginx/error.log;
#error_log /var/log/nginx/error.log notice;
#error_log /var/log/nginx/error.log info;
#pid /var/run/nginx.pid;
include /etc/nginx/modules.conf.d/*.conf;
events {
worker_connections 1024;
http {
include mime.types;
#log_format main '$remote_addr - $remote_user [$time_local] "$request" '
# '$status $body_bytes_sent "$http_referer" '
# '"$http_user_agent" "$http_x_forwarded_for"';
#access_log /var/log/nginx/access.log main;
sendfile on;
#tcp_nopush on;
#keepalive_timeout 0;
keepalive_timeout 65;
#tcp_nodelay on;
gzip on;
gzip_vary on;
gzip_min_length 10240;
gzip_proxied expired no-cache no-store private auth;
gzip_types text/plain text/css text/xml text/javascript application/x-javascript application/xml;
gzip_disable "MSIE [1-6]\.";
#gzip_disable "MSIE [1-6]\.(?!.*SV1)";
server_tokens off;
# override global parameters e.g. worker_rlimit_nofile
include /etc/nginx/*global_params;
OK, show:
ls -l /etc/nginx/conf.d/*.conf
-rw------- 1 root nginx 32 Nov 26 2020 /etc/nginx/conf.d/aa500_psa_tweaks.conf
-rw------- 1 root root 171 Jun 3 03:00 /etc/nginx/conf.d/brotli.conf
-rw-r--r-- 1 root root 452 Aug 16 11:45 /etc/nginx/conf.d/phusion-passenger.conf
-rw-r--r-- 1 root root 567 Sep 6 20:09 /etc/nginx/conf.d/ssl.conf
-rw-r--r-- 1 root root 37 Jul 17 2018 /etc/nginx/conf.d/sslv3-disable.conf
-rw------- 1 root nginx 391 Oct 1 01:18 /etc/nginx/conf.d/zz010_psa_nginx.conf
OK not much to sift through...
Try:
grep -i ssl_cert /etc/nginx/conf.d/*.conf
nothing
hmm...
Try:
grep -i chain /etc/nginx/conf.d/*.conf
Nothing again...
Plesk is hiding...
Try:
grep -i server /etc/nginx/conf.d/*.conf
/etc/nginx/conf.d/aa500_psa_tweaks.conf:server_names_hash_max_size 780;
/etc/nginx/conf.d/ssl.conf:ssl_prefer_server_ciphers on;
/etc/nginx/conf.d/zz010_psa_nginx.conf:include /etc/nginx/plesk.conf.d/server.conf;
I should be doing my Latin homework haha
Well it's definitely time for that - we've hit a brick wall !
We might as well delete all useless posts
My problem is I gotta get these sites working, they are for funeral homes and people can't pay to have bodies picked up, so kinda pressing and I have no idea....
Plesk forum?
What is it we're looking for?
I can try that, what am I asking?
Where the certs are entered/maintained; so we can tweak them until things work for you.
Modifying the chain.
anything useful there?
/usr/local/psa/var/certificates/ maybe?
Try (wildly searching):
find / -name *.pem
find / -name certificates
P.S. I'm going to go back and delete some of this noise we've made - sorry about that
hmm... I can only delete my own posts
what file am I looking for, that's a big response... each don=main has a chain.pem and fullchain.pem
