Hello
I tried install certificate but I don’t started NGINX and I received error message… Okay, I configured NGINX and tried again, but now I receive this message:
Failed authorization procedure. www.mywebsite.com.br (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.mywebsite.com.br/.well-known/acme-challenge/MilcDzy6hX4-Cem3aW3iD9960nIvQWi12OamTxJe9q8: “\n\n404 Not Found\n\nNot Found
\n<p”, mywebsite.com (http-01): urn:ietf:params:acme:error:unknownHost :: The server could not resolve a domain name :: No valid IP addresses found for mywebsite.com
** - The following errors were reported by the server:**
** Domain: mywebsite.com**
** Type: unknownHost**
** Detail: No valid IP addresses found for mywebsite.com**
** To fix these errors, please make sure that your domain name was**
** entered correctly and the DNS A/AAAA record(s) for that domain**
** contain(s) the right IP address.**
** Domain: www.mywebsite**
** Type: unauthorized**
** Detail: Invalid response from**
** http://www.mywebsite/.well-known/acme-challenge/MilcDzy6hX4-Cem3aW3iD9960nIvQWi12OamTxJe9q8:**
** "\n\n404 Not**
** Found\n\nNot Found
\n<p"**
Please, is possible I remove this archives and install again?? Just problem was NGINX inactive but now are started, is possible I install again?
