My domain is: Aushdc.org.au
I ran this command: na
I can login to a root shell on my machine (yes or no, or I don't know): No
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Yes - go daddy
or certbot-auto --version
if you're using Certbot):
Our membership organisation is on wild apricot membership system. It uses lets encrypt for the security certificates. The wild apricot system is saying that our certificates are in place but the browser says they're not- all users are getting security alert when they try to open the page. Apparently it was renewed on 30th April 2021. Ive checked with go daddy that our settings are correct.
I don't know what else to do or check. Help!?!
