My domain is: cockpit-controlpanel.com
I ran this command: sudo certbot certonly --standalone
It produced this output:IMPORTANT NOTES:
Domain: cockpit-controlpanel.com
Type: connection
Detail: Fetching
http://cockpit-controlpanel.com/.well-known/acme-challenge/_6cR9z8IpdDLbdaW5MRKQCjBPdTBDqquf16EckwELy8:
Timeout during connect (likely firewall problem)To fix these errors, please make sure that your domain name was
My web server is (include version): cockpit ?.??
The operating system my web server runs on is (include version): Debian 10
My hosting provider, if applicable, is: 1&1 IONOS
yes - cockpit ?.??
