[GUIDE] How to create Wildcard SSL with SSLForFree
This post was flagged by the community and is temporarily hidden.
What makes you think it’s appropriate to give out these login credentials? And since sslforfree.com no longer obtains certs from Let’s Encrypt (they use ZeroSSL certs instead), I don’t see that this is relevant to this forum.
So take this as an opportunity to start doing what you always should have been doing: issue your own certs using client software that you run on your server. Let’s Encrypt was never intended to be used with a web-based front-end, and using one puts you at the mercy of the operators of that site–as you’ve now experienced.
