<IfModule mod_ssl.c>
<VirtualHost *:443>
# specifies what hostname must appear in the request's Host: header to
#ServerName www.example.com
DocumentRoot /home/linux/www/website
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
RewriteEngine on
# Some rewrite rules in this file were disabled on your HTTPS site,
# because they have the potential to create redirection loops.
# RewriteCond %{SERVER_NAME} =davisworthing.co.uk
# RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
ServerName davisworthing.co.uk
ServerAlias www.davisworthing.co.uk
SSLCertificateFile /etc/letsencrypt/live/davisworthing.co.uk/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/davisworthing.co.uk/privkey.pem
</VirtualHost>
</IfModule>
<VirtualHost *:443>
RewriteEngine on
RewriteCond %{SERVER_NAME} =www.davisworthing.co.uk
RewriteRule ^ https://davisworthing.co.uk%{REQUEST_URI} [END,NE,R=permanent]
i hope that right cos as i said i relly am new at all this
no. go with this:
<VirtualHost *:443>
# modules, e.g.
RewriteEngine on
</VirtualHost>
</IfModule>
did you remove the āmanaged by certbotā comments? donāt do that.
ok ive copyed that ok
is there any more comand run ?
or is that is i can walk away and have a cuppa
you should reload apache (systemctl reload apache2). if there are no errors, have your cuppa
yep i reload it and it all working⦠can u check ur end if it all ok ? plz
looks good from here.
well thank u so much for all ur help im going to start backing all this up oh this might help u as well i just l just found
