Ackis
March 10, 2020, 2:28am
21
I didn't issue any command with webroot. I just ran certbot renew -a nginx like you suggested.
There's a bug with nginx where the installer doesn't work on some installs, so I was forced to use the webroot method.
opened 04:16AM - 04 Oct 19 UTC
closed 07:52PM - 27 Jul 20 UTC
bug
area: nginx
Detailed conversation could be found here:
https://community.letsencrypt.org/t/… cannot-renew-create-a-new-cert-when-i-had-no-issue-previously/103040/
## My operating system is (include version):
Ubuntu 18.04.3 LTS
Nginx 1.17.4 (note, this isn't the version of nginx that's part of Ubuntu's repo's)
## I installed Certbot with (certbot-auto, OS package manager, pip, etc):
## I ran this command and it produced this output:
`sudo certbot renew --cert-name ackis.duckdns.org --debug-challenges --dry-run`
Processing /etc/letsencrypt/renewal/ackis.duckdns.org.conf
http-01 challenge for ackis.duckdns.org
Challenges loaded. Press continue to submit to CA. Pass "-v" for more info about
challenges.
Attempting to renew cert (ackis.duckdns.org) from /etc/letsencrypt/renewal/ackis.duckdns.org.conf produced an unexpected error: Failed authorization procedure. ackis.duckdns.org (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from https://ackis.duckdns.org/.well-known/acme-challenge/7bO_DNxtDDyO_hPdRJcpGWEJHaLTRwtTsMWpWtQREDE [174.3.126.96]: "<html>\r\n<head><title>404 Not Found</title></head>\r\n<body>\r\n<center><h1>404 Not Found</h1></center>\r\n<hr><center>nginx</center>\r\n". Skipping.
/etc/letsencrypt/live/ackis.duckdns.org/fullchain.pem (failure)
Domain: ackis.duckdns.org
Detail: Invalid response from
## Certbot's behavior differed from what I expected because:
Certbot should have renewed the certificate.
## Here is the relevant nginx server block or Apache virtualhost for the domain I am configuring:
# HTTP server - redirect to HTTPS
listen 80;
listen [::]:80;
server_name www.ackis.duckdns.org ackis.duckdns.org;
return 301 https://ackis.duckdns.org$request_uri;
# Workaround LE and certbot not working with nginx
root /var/www/letsencrypt;
access_log syslog:server=localhost,tag=nginx_access_internet,severity=info;
error_log syslog:server=localhost,tag=nginx_error_internet;
add_header Strict-Transport-Security "max-age=31536000;";
add_header X-Frame-Options SAMEORIGIN;
add_header X-Content-Type-Options nosniff;
add_header X-XSS-Protection "1; mode=block";
# www domain - redirect to domain without www
listen 443 ssl;
listen [::]:443 ssl;
server_name www.ackis.duckdns.org;
ssl_certificate /etc/letsencrypt/live/www.ackis.duckdns.org/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/www.ackis.duckdns.org/privkey.pem;
server_tokens off;
etag off;
listen 443 ssl default_server;
server_name ackis.duckdns.org;
ssl_certificate /etc/letsencrypt/live/ackis.duckdns.org/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/ackis.duckdns.org/privkey.pem; # managed by Certbot
server_tokens off;
etag off;
location ~* /\.\./ {
deny all;
return 404;
location ~* "^(?:.+\.(?:htaccess|make|txt|test|markdown|md|engine|inc|info|install|module|profile|po|sh|.*sql|theme|tpl(?:\.php)?|xtmpl)|code-style\.pl|/Entries.*|/Re$
return 404;
location = /favicon.ico {
try_files /favicon.ico =204;
root /var/www/internet;
index index.html;
location /nginx_status {
access_log syslog:server=localhost,tag=nginx_access_admin,severity=info;
error_log syslog:server=localhost,tag=nginx_error_admin;
allow 192.168.0.0/24;
deny all;
auth_basic "Restricted access";
auth_basic_user_file /etc/nginx/auth/admin.htpasswd;
stub_status on;
I'm willing to get rid of it, if you think it'll help. I did for the ackis.duckdns.org domain (which is why I had the configuration error, I had to manually edit the config file) and it didn't seem to make a difference.
9peppe
March 10, 2020, 8:32am
22
did you not use, at any point in time, something that looks like certbot renew|run -a webroot -w /var/www/letsencrypt [-d domain] ?
try putting a file in that directory and check if you can see it from http://plexpy.ackis.duckdns.org/.well-known/acme-challenge/yourfile.txt
(or, better, try putting a file in /var/www/letsencrypt/.well-known/acme-challenge/)
Ackis
March 10, 2020, 8:42pm
23
Yes I did - for all my domains that came up for renewal.
Did that - was able to see the file after messing with permissions, and then I was able to renew a couple certs.
9peppe
March 10, 2020, 8:54pm
24
and the others gave what error?
Ackis
March 10, 2020, 9:10pm
25
They've just been errors with the automatic nginx install so far - I've just had to convert them over to the webroot method. It looks like it was a permissions error.
I thought I had tested that out because I put a file in /var/www/letsencrypt and tried to access it via curl, but couldn't, but when you told me to put a file in /var/www/letsencrypt/.well-known/acme-challenge/, that's when I clued in that it may have been permissions. I'm not sure how it could have been because nothing changed there - it was an empty folder with www-data owning it, but who knows. It's working now at least so I'm able to renew the certs that need to be renewed.
Going to get them all renewed over the next few days here, and hopefully just have it left on so I can forget about it and have everything just work.
Appreciate your help and patience with me.
9peppe
March 10, 2020, 9:13pm
26
did you mkdir the directories before putting the file in there?
(you can become www-data with sudo -u www-data -s /bin/bash)
Ackis
March 11, 2020, 4:41am
27
Not originally. I had thought that the webroot declaration handled that. E.g. plexpy.ackis.duckdns.org/.well-known/acme-challenge/ was mapped directly to /var/www/letsencrypt/. So by having those folders we ended up with plexpy.ackis.duckdns.org/.well-known/acme-challenge/.well-known/acme-challenge/ .
They exist in there now though (well earlier this afternoon before I made that other post).
Hi @9peppe ,
How can I check such information on our website hubbroker.com ?
9peppe
March 11, 2020, 8:02am
29
it does. but that doesn't do you any good if you put files inside manually.
You want to see the response headers?
either open the network tab in your browser development tools, or run curl -I http[s]://website in a terminal (install curl if it's not)
Ackis
March 12, 2020, 3:13am
30
I'm not quite following you - if I put a file inside shouldn't it be handled like a symbolic link to a directory?
9peppe
March 12, 2020, 9:28am
31
the webroot declaration will create the .well-known/acme-challenge directory if it does not exist, but that doesn’t mean you won’t have to do the same, you can’t put files inside a non-existing directory (the webroot declaration cleans up after itself)
system
Closed
April 11, 2020, 9:28am
32
