ardesa
March 4, 2021, 12:11pm
1
Bonjour,
Je peux lire des réponses en Anglais : Oui
Mon nom de domaine est : extranet-rec.mudetaf.fr
J’ai exécuté cette commande : sudo certbot --apache -d extranet-rec.mudetaf.fr --rsa-key-size 4096 --agree-tos --no-eff-email
Elle a produit cette sortie :
challenge failed
type : connection
detail : fetching
Mon serveur Web est (inclure la version) : apache2
Le système d’exploitation sur lequel mon serveur Web s’exécute est (version incluse) : Ubuntu LTS
Mon hébergeur, le cas échéant, est : local
Je peux me connecter à un shell root sur ma machine (oui ou non, ou je ne sais pas) : oui
J’utilise un panneau de configuration pour gérer mon site (non, ou fournit le nom et la version du panneau de configuration) : non
Merci,
Christophe
Hi @ardesa
please read your error message.
Your port 80 / http doesn't answer. That's required if you want to use http validation.
Change that - router, firewall, not running webserver.
ardesa
March 4, 2021, 2:25pm
3
Hi @JuergenAuer
Thanks
I don't understand what you mean by saying my port 80 doesn't answer : I can access the url within a navigator.
please note that I'm not the domain's administrator, just a developer who's trying to make it works
he just said to me that he opened the port 80, 443 but didn't gave access to ping
That's inside your local network.
But Letsencrypt can't connect your domain, I can't with my browser, extranet-rec.mudetaf.fr - Make your website better - DNS, redirects, mixed content, certificates shows timeouts.
A public visible port 80 / http is required if you want to use http validation.
Check your firewall.
ardesa
March 4, 2021, 3:22pm
5
not at all, it works from my computer outside the network and from my phone, no VPN connected
ardesa
March 4, 2021, 6:45pm
6
no need to go further, thanks for your help
the administrator found the problem : this URL was blocked to outside France by a firewall's rule
