Generated certificate not valid
jojocommunication.com
sudo certbot certonly -v --manual --manual-public-ip-logging-ok --email --agree-tos --domain jojocommunication.com --rsa-key-size 2048 --config-dir .jojo --work-dir .jojo --logs-dir .jojo
Saving debug log to /Users/sam/.jojo/letsencrypt.log
Certificate is due for renewal, auto-renewing...
Renewing an existing certificate for jojocommunication.com
http-01 challenge for jojocommunication.com
Create a file containing just this data:
wCMcoXGnnEmUS_ynoj0IuTZvjGmchlIxSHqmqK-aY3w._ltXZQw-XneAeIlo69Z1-OexJEWmx8SLlTTxGvB4gKY
http://jojocommunication.com/.well-known/acme-challenge/wCMcoXGnnEmUS_ynoj0IuTZvjGmchlIxSHqmqK-aY3w
Press Enter to Continue
Certificate is saved at: /Users/sam/.jojo/live/jojocommunication.com/fullchain.pem
Key is saved at: /Users/sam/.jojo/live/jojocommunication.com/privkey.pem
This certificate expires on 2023-09-07.
NEXT STEPS:
  • This certificate will not be renewed automatically. Autorenewal of --manual certificates requires the use of an authentication hook script (--manual-auth-hook) but one was not provided. To renew this certificate, repeat this same certbot command before the certificate's expiry date.
Unsure
Unsure.
A Small Orange shared hosting service
No
yes, cpanel 94.0.25. Using "SSL/TLS Status" menu, viewing existing certificate and selecting upgrade. Copying fullchain.pem to "Certificate (CRT)" results in "The certificate is not valid".
certbot 2.3.0 installed using brew on a Mac; upgraded to 2.6.0 with the same result, less the website challenge and an indication that --manual-public-ip-logging-ok was no longer required.
I'm just not sure where to go to next given I've followed this process before and not had issues. Any help gratefully received. I'm sure I've done something simple wrong...
Sam
Your website currently already has a Let's Encrypt certificate installed (ECDSA instead of RSA). So it might be the actions you're currently taking with Certbot are not required at all. Perhaps your hosting provider already has taken care of the certificate part.
However, there are some issues:
Thanks for the help. The ECDSA certificate was generated using the same process I thought:
Domains: * jojocommunication.com
Issuer: Let's Encrypt
Key: ECDSA, P-256/prime256v1 (02f18d85 …)
Expiration: Jun 10, 2023 11:18:43 PM
I'll try and sort the http redirect. By mixed content, do you mean both encrypted and not?
Referring to http:// URLs from a website loaded through HTTPS (https://). See e.g. https://www.whynopadlock.com/
Understood.
So should be trying to generate an RSA certificate?
Apparently because I am not auto-renewing certificates under the current settings I cannot redirect http to https.
Shouldn't matter.
One thing should not have anything to do with the other.
If the site serves both [HTTP and HTTPS], then it should be able to redirect the HTTP To HTTPS.
I thought that as well, but apparently the server is not configured to redirect. A decision by the hosting company I assume.
Both are being handled by WordPress.
If you can control that [for your site], then you should be able to have it redirect HTTP to HTTPS for you.
Thanks! Will check that out.
