Yes, but does icecast know to look for it there?
yes it it's on my xml file it 's just when i past it here it re move < >
ok, to avoid that you can use ` backticks
`<xml>` becomes <xml>
That says it is 5560 bytes. My fullchain files (long chain) are about 5600 bytes. My privkey files are about 1700 for a total close to 7300. Are you sure you have combined the fullchain and privkey pem files to make the bundle.pem?
ls -l /opt/bitnami/letsencrypt/certificates/
total 20
-rw------- 1 bitnami root 5333 Mar 15 22:42 hooggar.com.crt
-rw------- 1 bitnami root 3751 Mar 15 22:42 hooggar.com.issuer.crt
-rw------- 1 bitnami root 232 Mar 15 22:42 hooggar.com.json
-rw------- 1 bitnami root 227 Mar 15 22:42 hooggar.com.key
this my cat command i take the .crt and the .key file
cat /opt/bitnami/letsencrypt/certificates/hooggar.com.crt /opt/bitnami/letsencrypt/certificates/hooggar.com.key > /usr/share/icecast2/bundle.pem
How many times does the word "BEGIN" (all caps) appear in that file?
(It should be more than two. Either 3 or 4)
cat /usr/share/icecast2/bundle.pem|grep BEGIN |wc -l
4
based on the command i have 4 on the file i concatenated however in my case i dont have a fullchain file i have only this:
total 20
I think your hooggar.com.crt is the fullchain (based on size and # of BEGINs).
But, I think something is wrong with the key. What does this say?
sudo openssl rsa -check -noout -in /opt/bitnami/letsencrypt/certificates/hooggar.com.key
It is normally closer to 1700 bytes.
Do not show us the key file though - private keys must be kept private!
Now I'm curious about mine:
- RSA4096 on R3: 5946
- RSA2048 on R3: 5609
- P-256 on R3: 5329
- P-256 on E1: 3968
(What the... How are they so close? -- they're not, I checked the wrong certificate)
(The keys are another story, ~3200, ~1700 and ~300)
So, it looks like you were concatenating the files correctly.
We don't know why icecast would not support ECDSA given it uses openssl.
I don't have any other ideas. Maybe @9peppe or someone else will think of something more. Best of luck.
What I don't get is why would Icecast just ignore some but not others of those configuration options.
I don't know either. Is there an icecast community somewhere?
Should OP drop plans to use TLS with icecast directly and try again reverse proxying with nginx? I don't know that either.
One prior icecast poster had to drop TLS because some (all?) of the hardware radios that would connect to their icecast server did not support HTTPS.
Yeah, I remember. But serving both http and https should be allowed, I think.
so far i have 2 VM on google cloud and 1 in oracle cloud
the google cloud vm use debian 10 and the bitnami nginx package
the oracle vm is under centos 7 but use httpd apache server
i will install lets incrypte (cerbot) and see if it will fail like on Debian
Wait. If you can install WordPress/bitnami somewhere and icecast somewhere else it's probably better. That way you can just use a different subdomain and hope TLS works this time.
i have the same problem on the second server
http://www.usdzradio.live:8443/mount
the port come up as http not as http
On the second server you can use 80 and 443 ![]()
Maybe telling it to use 443 will shame icecast into actually using TLS.
