Site is accessible just no cert. I'll have the ports closed by the time you read this. But yes can access with rocket.pmsh.net
Thanks legends, what's left of my brain is fried.
My domain is: rocket.pmsh.net
I ran this command: certbot --nginx
It produced this output: Requesting a certificate for rocket.pmsh.net and www.rocket.pmsh.net
Domain: rocket.pmsh.net
Detail: Invalid response from http://rocket.pmsh.net/.well-known/acme-challenge/kwyhqfAlTo_OZOQy0FOgjwtLUhsqdrHruQ8ilr9a79w [101.118.8.58]: "\n\n\n <link rel="stylesheet" type="text/css" class="meteor-css " href="/6cbabb4e17621234bc6ff688395"
Domain: www.rocket.pmsh.net
Detail: Invalid response from http://www.rocket.pmsh.net/.well-known/acme-challenge/4YhSzAcZ-FHfAimwBW2Nv3MLGdZpZcmmff42Lse866A [101.118.8.58]: "\n\n\n <link rel="stylesheet" type="text/css" class="meteor-css " href="/6cbabb4e17621234bc6ff688395"
My web server is (include version): snapy rocketchat 3.18.1
The operating system my web server runs on is (include version): Ubuntu 21.4
The version of my client is : 1.19.0
griffin
September 25, 2021, 4:57pm
#2
Welcome to the Let's Encrypt Community
As you can tell by the many, many thousands of threads in our #help category, you aren't anywhere close to the first to struggle with obtaining a certificate, so don't be too hard on yourself. (though I did get a laugh out of your topic title. )
From your certbot output it looks like you might have some type of rewrite/redirect interfering. Without your webserver being accessible (port 80 open), I cannot leverage any of my debugging tools.
rg305
September 25, 2021, 9:41pm
#3
You are asking for our help, but seem to have shutdown (presumably to resolve this on your own before you reopen).
If you are to go at it alone, I'd start by reviewing the entire nginx
config, with:
sudo nginx -T
Cool.. port 80 was open at time cert was being issued. How I understand the link you shared, port 80 on the Domain provider should be set up as a redirection to 443 and on server side port 80 should direct traffic to servers IP as well as 443? The rocketchat instants is using 3000.
Thank you for assisting
(M_P)
Cheers, I'll get logs and post here. Hopefully I can get my head around this, appreciate everyone's help.
(M_P)
nginx config
http {
# Basic Settings
sendfile on;
tcp_nopush on;
types_hash_max_size 2048;
# server_tokens off;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# Virtual Host Configs
Default server configuration
listen 80 default_server;
# SSL configuration
rg305
September 26, 2021, 5:03am
#8
There seems to be much missing from that output.
There is. Is it fine to post on public forum?
(M_P)
rg305
September 26, 2021, 12:45pm
#10
Yes, or you can send it to me directly via PM if you are worried.
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
# SSL Settings
# Logging Settings
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip2.conf:
load_module modules/ngx_http_geoip2_module.so;
# configuration file /etc/nginx/modules-enabled/70-mod-stream-geoip2.conf:
load_module modules/ngx_stream_geoip2_module.so;
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/png png;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
image/svg+xml svg svgz;
image/webp webp;
application/font-woff woff;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.wap.wmlc wmlc;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
application/vnd.openxmlformats-officedocument.wordprocessingml.document docx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet xlsx;
application/vnd.openxmlformats-officedocument.presentationml.presentation pptx;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
# configuration file /etc/nginx/sites-enabled/default:
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
# https://wiki.debian.org/Nginx/DirectoryStructure
# In most cases, administrators will remove this file from sites-enabled/ and
# leave it as reference inside of sites-available where it will continue to be
# updated by the nginx packaging team.
# This file will automatically load configuration files provided by other
# applications, such as Drupal or Wordpress. These applications will be made
# available underneath a path with that package name, such as /drupal8.
# SSL configuration
root /var/www/html;
server_name _;
try_files $uri $uri/ =404;
#location ~ \.php$ {
# include snippets/fastcgi-php.conf;
# # With php-fpm (or other unix sockets):
# fastcgi_pass unix:/run/php/php7.4-fpm.sock;
# # With php-cgi (or other tcp sockets):
# fastcgi_pass 127.0.0.1:9000;
# concurs with nginx's one
#location ~ /\.ht {
# deny all;
#server {
# listen 80;
# listen [::]:80;
# server_name example.com;
# root /var/www/example.com;
# index index.html;
# location / {
# try_files $uri $uri/ =404;
rg305
September 26, 2021, 1:54pm
#12
That config shows no signs of change since it was installed.
And the site remains unreachable.
curl -Iki http://rocket.pmsh.net/
Sorry first time.. configure nginx reverse proxy like this.
sudo nano /etc/nginx/conf.d/rocketchat.conf
upstream backend {
server 192.168.3.50:3000;
listen 80;
rocket.pmsh.net ;
access_log /var/log/nginx/rocket.chat.access.log;
error_log /var/log/nginx/rocket.chat.error.log;
proxy_pass http://backend/;
proxy_http_version 1.1;
proxy_set_header Connection "upgrade";
proxy_set_header Host $http_host;
proxy_set_header X-Forward-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forward-Proto http;
proxy_set_header X-Nginx-Proxy true;
proxy_redirect off;
rg305
September 27, 2021, 2:10am
#14
The site remains unreachable.
Does it even work from within the same network?
Do you have a firewall?
Sorry,
Yes have blocked it ATM away for the week. That's what I did wrong I didn't config nginx at all ( I'm a noob first time ). I'll have a crack when I'm back.
Thanks for your help. (M_P)
system
closed
October 29, 2021, 12:09pm
#16
