I use let’s encrypt to manage my cert for my home domain.
Few days ago I noticed that I cannot connect to a subdomain.
The error I see is
# 400 Bad Request - nginx/1.18.0
I check web app and it’s working fine. Also The cert is right.
I did not changed anything is my config, just updated my containers.
Can someone please help me?
Below config for the web app - FreshRSS - freshrss.subdomain.conf
# make sure that your dns has a cname set for freshrss
listen 443 ssl;
listen [::]:443 ssl;
server_name freshrss.*;
include /config/nginx/ssl.conf;
client_max_body_size 0;
# enable for ldap auth, fill in ldap details in ldap.conf
#include /config/nginx/ldap.conf;
# enable the next two lines for http auth
#auth_basic "Restricted";
#auth_basic_user_file /config/nginx/.htpasswd;
# enable the next two lines for ldap auth
#auth_request /auth;
#error_page 401 =200 /login;
include /config/nginx/proxy.conf;
resolver 127.0.0.11 valid=30s;
set $upstream_freshrss freshrss;
proxy_pass http://$upstream_freshrss;
proxy_redirect off;
proxy_buffering off;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Port $server_port;
proxy_cookie_path / "/; HTTPOnly; Secure";
proxy_set_header Authorization $http_authorization;
proxy_pass_header Authorization;
