Forum on the MyBB engine does not start
My domain is:www.forumcoopgame.pl
I ran this command:letsencrypt
It produced this output:pass
My web server is (include version):MyBB 1.8x
The operating system my web server runs on is (include version):Debian 9
My hosting provider, if applicable, is:Contabo
I can login to a root shell on my machine (yes or no, or I don’t know):Yes
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):Webmin
Hello
I have a problem with the forum certifica on the mybb engine.
The certificate passes normally but the forum stops working.
The website www.coopgame.pl is without a problem.
However, no forum, I tried to switch port to 443, I have a Webmin vps panel and a few websites.
Regards
Your forum doesn’t work due to bad http links in https mode. The best way to fix it is (since I don’t know forum software) change your site link to https (or if there is any force https options)
Thank you
As @stevenzhu indicated, MIXED CONTENT is a serious issue that should be addressed on all websites (not just yours).
You might want to take a look at the following links. Could help a whole bunch.
https://www.hardenize.com/report/coopgame.pl/1524155196
https://www.hardenize.com/report/forumcoopgame.pl/1524154435
Good Luck
Rip
