fugee
August 14, 2019, 2:57pm
#1
Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: kingbiscuitblues.com
sudo /opt/certbot/certbot-auto
403 forbidden
nginx
ubuntu 18.04 LTS
no
or certbot-auto --version
if you’re using Certbot):
certbot 0.37.1
Hi @fugee
good news: You have created some new certificates ( https://check-your-website.server-daten.de/?q=kingbiscuitblues.com#ct-logs ):
Issuer
not before
not after
Domain names
LE-Duplicate
next LE
Let’s Encrypt Authority X3
2019-08-14
2019-11-12
*.kingbiscuitblues.com, kingbiscuitblues.com
2 entries
duplicate nr. 1
2019-08-13
2019-11-11
bluegrasscounty.com , homerobotdepot.com , ignatzmouse.com , jazznouvel.com , kingbiscuitblues.com , mandopopnews.com , roboticadepot.com , rythmreview.com , servicemouse.com , sockpublicist.com , thekidslepthere.com , www.bluegrasscounty.com , www.homerobotdepot.com , www.ignatzmouse.com , www.jazznouvel.com , www.kingbiscuitblues.com , www.mandopopnews.com , www.roboticadepot.com , www.rythmreview.com , www.servicemouse.com , www.sockpublicist.com , www.thekidslepthere.com , www.xingfushou.com , xingfushou.com
24 entries
duplicate nr. 2
2019-08-13
2019-11-11
24 entries
duplicate nr. 1
2019-07-19
2019-10-17
24 entries
But that’s curious, one certificate with 24 domain names, one wildcard certificate.
You use the certificate with 24 domain names:
CN=bluegrasscounty.com
14.08.2019
12.11.2019
expires in 90 days
bluegrasscounty.com, homerobotdepot.com, ignatzmouse.com, jazznouvel.com,
kingbiscuitblues.com, mandopopnews.com, roboticadepot.com, rythmreview.com,
servicemouse.com, sockpublicist.com, thekidslepthere.com, www.bluegrasscounty.com,
www.homerobotdepot.com, www.ignatzmouse.com, www.jazznouvel.com, www.kingbiscuitblues.com,
www.mandopopnews.com, www.roboticadepot.com, www.rythmreview.com, www.servicemouse.com,
www.sockpublicist.com, www.thekidslepthere.com, www.xingfushou.com,
xingfushou.com - 24 entries
But bad news: There is really a http status 403:
Looks like certbot has created a new vHost.
What says
nginx -T
Perhaps you have two vHosts. One old, working. One new, now with the wrong root without permissions.
Perhaps change the root of your vHost.
fugee
August 14, 2019, 5:21pm
#3
What do you mean by 2 vHosts Do you mean in my one nginx.conf file? They’re all vhosts sudo nginx -T
reports tnhat my nginx.conf is valid
fugee
August 14, 2019, 6:09pm
#4
I thought I was allowed to have 2 one for http which will redirect, one for ssl
Please share the output of nginx -T
Google lists a lot of content of your domain. Is this your content? If yes, you should fix the 403. Or are you a new domain owner?
fugee
August 14, 2019, 6:40pm
#6
It’s my content Shouldn’t I be able to use certbot-auto? Why should I have to do it manually for each domain?
schoen
August 14, 2019, 10:39pm
#7
Could you indicate the complete certbot-auto
command that you’re running here on the server?
fugee
August 14, 2019, 10:47pm
#8
fugee
August 15, 2019, 2:17pm
#9
How can running a certbot command result in 403 forbidden It doesn’t make sense for me to look at permissions when it was returning expired certificate before running certbot
It’s not certbot, it’s your wrong configured webserver.
fugee
August 15, 2019, 3:28pm
#11
My website’s directories should be owned by who (for nginx) ?
What was the exact and full error message you got?
fugee
August 15, 2019, 5:17pm
#13
No such file or directory
Can you paste the command you ran and its complete output?
schoen
August 15, 2019, 6:13pm
#15
Certbot invites a bot from the Let’s Encrypt CA to check the proof that it’s created that you control the domain. The bot will connect to your web service. If it encounters an error, like a 403, it will tell Certbot about the error and then Certbot will tell you.
Certbot is in that case just reporting what an external bot saw when it tried to connect in order to validate your control over the domain.
fugee
August 15, 2019, 6:41pm
#16
It seems the problem is nginx doesn’t understand I’m serving a Ruby On Rails application because it’s looking for resource paths under public
system
closed
September 14, 2019, 6:51pm
#17
