[root@flydubbo flydubbo]# sudo apachectl -t -D DUMP_VHOSTS
Passing arguments to httpd using apachectl is no longer supported.
You can only start/stop/restart httpd using this script.
If you want to pass extra arguments to httpd, edit the
/etc/sysconfig/httpd config file.
VirtualHost configuration:
*:80 is a NameVirtualHost
default server flydubbo.com (/etc/httpd/conf/httpd.conf:160)
port 80 namevhost flydubbo.com (/etc/httpd/conf/httpd.conf:160)
alias www.flydubbo.com
port 80 namevhost sylloge.com.au (/etc/httpd/conf/httpd.conf:171)
alias www.sylloge.com.au
*:443 is a NameVirtualHost
default server flydubbo.com (/etc/httpd/conf.d/ssl.conf:56)
port 443 namevhost flydubbo.com (/etc/httpd/conf.d/ssl.conf:56)
port 443 namevhost sylloge.com.au (/etc/httpd/conf/httpd-le-ssl.conf:2)
port 443 namevhost flydubbo.com (/etc/httpd/conf/httpd-le-ssl.conf:13)
[root@flydubbo flydubbo]# sudo certbot certificates
Found the following certs:
Certificate Name: sylloge.com.au
Domains: sylloge.com.au flydubbo.comwww.flydubbo.com www.sylloge.com.au
Expiry Date: 2019-10-23 14:06:51+00:00 (VALID: 86 days)
Certificate Path: /etc/letsencrypt/live/sylloge.com.au/fullchain.pem
Private Key Path: /etc/letsencrypt/live/sylloge.com.au/privkey.pem
That is what will be causing the self-signed issue.
One of those is properly configured with your Letβs Encrypt certificate, and the other one will have the self-signed certificate.
Take a look inside, figure out which file is the right one, and get rid of the other one. Seems like ssl.conf is probably the one you want to get rid of, but double-check!
thanks for the quick answer, makes sense
I corrupted the ssl.conf file and now apache wont start
so will be a while sorting that out before i know if i fixed it
