First cert install - unauthorized
Can anyone help with first time install of a cert?
www.wrightstrawmanor.ddns.net
sudo certbot --apache
ubuntu 18.04
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):No
My .conf looks like this
<VirtualHost *:80>
# specifies what hostname must appear in the request’s Host: header to
    ServerName wrightstrawmanor.ddns.net
    ProxyPass /zm http://192.168.0.66/zm
    ProxyPassReverse /zm http://192.168.0.66/zm
    # error, crit, alert, emerg.
    # modules, e.g.
    #LogLevel info ssl:warn
vim: syntax=apache ts=4 sw=4 sts=4 sr noet
As you are proxying the viewers to another internal server, you’ll need to exempt the .well-known/acme-challenge folder from being proxied to the backend server.
Thank you
I think that should already be the case since it looks like only the URL path /zm is being proxied.
That being said I don’t know what’s actually going wrong here.
@Bruce69 could you share the output of the following command?
sudo apachectl -S
Hi
Thank you for replying. Here is the response
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 192.168.0.55. Set the 'ServerName' directive globally to suppress this message
VirtualHost configuration:
*:80 is a NameVirtualHost
default server wrightstrawmanor.ddns.net (/etc/apache2/sites-enabled/000-cctv.conf:1)
port 80 namevhost wrightstrawmanor.ddns.net (/etc/apache2/sites-enabled/000-cctv.conf:1)
port 80 namevhost wrightstrawmanor.ddns.net (/etc/apache2/sites-enabled/000-default.conf:1)
ServerRoot: "/etc/apache2"
Mutex proxy: using_defaults
Mutex proxy-balancer-shm: using_defaults
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
Hmm, so you have two VirtualHosts for the same name and port in two different files (000-cctv.conf and 000-default.conf) - I guess that might be confusing certbot. Is that how you intended to configure it? I don’t think they can both function at the same time - if you don’t need one, try disabling it with a2dissite and see if that helps.
I was just following some guide. its my first time setting this up for a home cctv system. should i delete 000-default.conf?
If you’re not using it, yes. Just delete /etc/apache2/sites-enabled/000-default.conf which should be a symbolic link - don’t delete the actual file it links to, just in case.
That worked, installed the cert etc however when you go to https://wrightstrawmanor.ddns.net or https://wrightstrawmanor.ddns.net/zm it does not work.
You may need to configure your router to forward port 443 to the Apache server. Since the validation worked I guess you already did port 80, so just repeat whatever you did to make that work, but on port 443.
Thank you thats solved it
