My domain is:www.hensberry.xyz
I ran this command: sudo certbot --apache -d hensberry.xyz -d www.hensberry.xyz
It produced this output: https://pastebin.com/FwibCqXKm, was too long to put here
My web server is (include version): Apache/2.4.43 (Unix)
The operating system my web server runs on is (include version): Arch Linux (Latest updates)
My hosting provider, if applicable, is: Self Hosted
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): not sure, i just use Namecheaps website to change DNS stuff.
or certbot-auto --version
if you’re using Certbot): certbot 1.5.0
Some more info.
ufw status : Status: active
22/tcp LIMIT Anywhere
80/tcp ALLOW Anywhere
443/tcp ALLOW Anywhere
27020 ALLOW Anywhere
7777 ALLOW Anywhere
25565 ALLOW Anywhere
22/tcp (v6) LIMIT Anywhere (v6)
80/tcp (v6) ALLOW Anywhere (v6)
443/tcp (v6) ALLOW Anywhere (v6)
27020 (v6) ALLOW Anywhere (v6)
7777 (v6) ALLOW Anywhere (v6)
25565 (v6) ALLOW Anywhere (v6)
Got port 80 and 443 tcp configured in both my router and my firewall. tried disabing firewall but didnt help.
i can access my website using my phones 4g, and my home network.
https://check-your-website.server-daten.de/?q=hensberry.xyz gives connection times out.
I created the .well-known/acme-challenge folder in my /srv/http/ and made sure to give it permissions in my apache config just in case.
Thats all really, i cant think of why it doesnt work. ive tried changing the configs around a bunch.
Thank you for any help!
