My domain is: afakto.com
certonly --webroot --webroot-path=/var/www/certbot --email contact@afakto.com --agree-tos --no-eff-email -d afakto.com -d www.afakto.com
certbot_1 | Challenge failed for domain afakto.com
certbot_1 | Challenge failed for domain www.afakto.com
certbot_1 | http-01 challenge for afakto.com
certbot_1 | http-01 challenge for www.afakto.com
certbot_1 | Cleaning up challenges
certbot_1 | Some challenges have failed.
certbot_1 | IMPORTANT NOTES:
certbot_1 | - The following errors were reported by the server:
certbot_1 |
certbot_1 | Domain: afakto.com
certbot_1 | Type: connection
certbot_1 | Detail: Fetching
certbot_1 | http://afakto.com/.well-known/acme-challenge/0gygpf9AAX8inTwkozLg9H4pYAA71Fd-tmb4qbo_ebs:
certbot_1 | Connection refused
certbot_1 |
certbot_1 | Domain: www.afakto.com
certbot_1 | http://www.afakto.com/.well-known/acme-challenge/_fgyrvrdGDM6f-YrNAqcCehgVup2KfSI2o5BMKDa1DE:
certbot_1 |
certbot_1 | To fix these errors, please make sure that your domain name was
certbot_1 | entered correctly and the DNS A/AAAA record(s) for that domain
certbot_1 | contain(s) the right IP address. Additionally, please check that
certbot_1 | your computer has a publicly routable IP address and that no
certbot_1 | firewalls are preventing the server from communicating with the
certbot_1 | client. If you're using the webroot plugin, you should also verify
certbot_1 | that you are serving files from the webroot path you provided.
afakto_certbot_1 exited with code 1
The operating system my web server runs on is (include version): Ubuntu 20.04
My hosting provider, if applicable, is: OVH
or certbot-auto --version
if you're using Certbot): docker image: certbot/certbot
