My domain is: et-c1.net
letsencrypt certonly --manual -d et-c1.net
Domain: et-c1.net
Type: connection
Detail: Fetching http://et-c1.net/.well-known/acme-challenge
/CT_tBWbWv71aUu8s1POCGV2i5rz9Lmd-Go_mb3TfBqg: Connection refused
Ubuntu 16.04.3 LTS
AWS / EC2
Yes
No
netstat -lpunta
(Not all processes could be identified, non-owned process info
will not be shown, you would have to be root to see it all.)
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN -
tcp 0 0 172.31.42.253:22 98.227.53.195:58831 ESTABLISHED -
tcp 0 0 172.31.42.253:22 73.58.154.245:57834 ESTABLISHED -
tcp6 0 0 :::22 :::* LISTEN -
udp 0 0 0.0.0.0:68 0.0.0.0:*
"import BaseHTTPServer, SimpleHTTPServer;
s = BaseHTTPServer.HTTPServer(('', 80), SimpleHTTPServer.SimpleHTTPRequestHandler);
s.serve_forever()"
File "", line 1, in
File "/usr/lib/python2.7/SocketServer.py", line 418, in init
self.server_activate()
File "/usr/lib/python2.7/SocketServer.py", line 440, in server_activate
self.socket.listen(self.request_queue_size)
File "/usr/lib/python2.7/socket.py", line 228, in meth
return getattr(self._sock,name)(*args)
socket.error: [Errno 98] Address already in use
If you did use --manual, please bear in mind that you’ll need to repeat the same steps before your certificate expires in 90 days! The --manual option doesn’t work with automated renewal.
