Failing renewal
Well I am either a total Dumba** or your a genius
All I did was remove 'RewriteEngine off' from 'hurricanepub.conf' restart apache, then I tested all works
I did not put the RewriteEngine statement in there so I assumed it had to be ON or OFF as long as Apache dose not put it back.
sudo certbot renew --dry-run
[sudo] password for web:
Processing /etc/letsencrypt/renewal/aquaprographix.com.conf
Simulating renewal of an existing certificate for aquaprographix.com and 9 more domains
Congratulations, all simulated renewals succeeded:
  /etc/letsencrypt/live/aquaprographix.com/fullchain.pem (success)
That doesn't follow:
Where each name has its' own vhost.
OR
I just don't understand what you mean by "attached to".
if I look at the certificate for any of those sites it shows all of them as Aquaprographix (wildcard)
I meen look at them from the lock in the web browser I just assumed thats how letsencrypt does it
does that make sence
If you use a browser and go to hurricanepub.com, click on the lock and view the cert
OK.
That just means that you are using one single cert for all your sites.
[one cert can contain up to 100 names]
But the sites themselves are not connected in any way.
Thus, the HTTP challenge request to site X must be satisfied by site X.
Both could be true :slight_smile: (sorry, couldn't resist)
No worries.
Neither could also be true :slight_smile: (sorry, couldn't resist)
LOL
My best laugh today !
No Worries thanks for your help I changed hurricanepub.conf to have no rewrite and allowed htaccess that site is very complex and takes a lot of tweaking I retested letsencrypt and fingers crossed im good to go now
