Failed authorization procedure for my domain
No NAT. Firewall from my Cloud provider where the server hosted.
Let's be sure you are at the right IP.
Show output of:
curl ifconfig.io
curl ifconfig.io
74.208.121.66
OK, that is the expected IP.
Please show the output of:
netstat -pant | grep -i listen | grep -E ':80|:443'
tcp   0   0 0.0.0.0:80     0.0.0.0:*    LISTEN    675/apache2
tcp   0   0 0.0.0.0:8080   0.0.0.0:*    LISTEN    11998/java
tcp   0   0 0.0.0.0:443    0.0.0.0:*    LISTEN    675/apache2
That shows Apache is listening on port 443.
Please show (again) the complete output of:
sudo apachectl -t -D DUMP_VHOSTS
And:
ls -l /etc/apache2/sites-enabled/
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 74.208.121.66. Set the 'ServerName' directive globally to suppress this message
VirtualHost configuration:
*:80 demo.hologram.cd (/etc/apache2/sites-enabled/payaraSite.conf:1)
root@srvhidsdemo:~#
root@srvhidsdemo:~#
root@srvhidsdemo:~#
root@srvhidsdemo:~#
root@srvhidsdemo:~#
root@srvhidsdemo:~#
root@srvhidsdemo:~# sudo apachectl -t -D DUMP_VHOSTS
root@srvhidsdemo:~# ls -l /etc/apache2/sites-enabled/
total 0
lrwxrwxrwx 1 root root 34 Apr 9 2020 payaraSite.conf -> ../sites-available/payaraSite.conf
Would you show the contents of the above file? Please add 3 backticks before and after so we see all the Apache config like this
contents of conf file
<VirtualHost *:80>
        # specifies what hostname must appear in the request's Host: header to
        #ServerName www.example.com
        ServerName demo.hologram.cd
        DocumentRoot /var/www/html
        # Allow access to the challenge directory
    <Directory /var/www/html/.well-known/acme-challenge/>
        Options None
        AllowOverride None
        Require all granted
    </Directory>
        # error, crit, alert, emerg.
        # modules, e.g.
        #LogLevel info ssl:warn
        ProxyPass /pepele/ !
        ProxyPass /ucc/ !
        ProxyPass /fondationasanti !
        ProxyPass /teledeclaration !
        ProxyPass /snedac/wp-admin !
        ProxyPass /snedac_new !
        ProxyPass /reports_bi !
        ProxyPass /evisa/ !
        ProxyPass /.well-known/ !
        ProxyPass /phpinfo.php !
        ProxyPass / http://localhost:8080/
        ProxyPassReverse / http://localhost:8080/
</VirtualHost>
vim: syntax=apache ts=4 sw=4 sts=4 sr noet
As a test can you try this and show us the result
sudo certbot certonly --webroot -w /var/www/html --dry-run -d demo.hologram.cd
Also, in your httpd.conf can you add a line for ServerName localhost
Yours is defaulting to the IP address and I wonder if that makes it an IP based default server that takes priority from your named VirtualHost.
Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org
http-01 challenge for demo.hologram.cd
Using the webroot path /var/www/html for all unmatched domains.
Failed authorization procedure. demo.hologram.cd (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: 74.208.121.66: Invalid response from http://demo.hologram.cd/.well-known/acme-challenge/0rlgHVztshaHkqFq7HLaWuVRR4settcp5E6BQ4lAuNQ: "<span style="color: #000000">\n0rlgHVztshaHkqFq7HLaWuVRR4settcp5E6BQ4lAuNQ.RE57Pkd71R5BawWsxegFEjBbd1q7Mj9lvIoe_bXGKPg</spa"
    Domain: demo.hologram.cd
    Detail: 74.208.121.66: Invalid response from
I cannot reproduce your error with Let's Debug or with my own test server. I always get the expected "404 Not Found" when trying an acme-challenge URL test.
The above http request should return the challenge token created by Certbot. And, the data inside the "span" tags looks like the proper challenge token. But, it should not have any html tags around it. I don't have an explanation for why Apache would do that but thought it might help to point it out anyway.
You need a location block for the challenges.
Without it, all the requests are being proxied.
I am pretty sure the above proxypass prevents proxy of acme challenge requests
But before, without this proxy, the same error would occur. Even when I remove the proxy from the configuration, it still doesn't work, and the certificate installation fails.
Can you tell me how to create this block, how and in which configuration file? Please, can you guide me exactly and give me the real clues to solve this problem?
I see you still have not gotten your cert or HTTPS working.
If you want more help, please show the current output of this. Thank you
*:80 localhost (/etc/apache2/sites-enabled/payaraSite.conf:1)
Can you make the change I described earlier and try getting a cert again? Let us know the result. Thanks.
These are the settings I've already made since the day you asked me to apply them, and I haven't modified the file yet.
