Failed authorization procedure - Could not connect to anwinity.com
My domain is: anwinity.com
certbot certonly --webroot -w /var/lib/tomcat8/webapps/ROOT -d anwinity.com -d www.anwinity.com
http-01 challenge for anwinity.com
http-01 challenge for www.anwinity.com
Using the webroot path /var/lib/tomcat8/webapps/ROOT for all unmatched domains.
Waiting for verification…
Failed authorization procedure. anwinity.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to anwinity.com, www.anwinity.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to www.anwinity.com
   Domain: anwinity.com
   Type:   connection
   Detail: Could not connect to anwinity.com
   Domain: www.anwinity.com
   Type:   connection
   Detail: Could not connect to www.anwinity.com
Distributor ID: Ubuntu
Description: Ubuntu 17.04
Release: 17.04
Codename: zesty
Using CATALINA_BASE: /usr/share/tomcat8
Using CATALINA_HOME: /usr/share/tomcat8
Using CATALINA_TMPDIR: /usr/share/tomcat8/temp
Using JRE_HOME: /usr
Using CLASSPATH: /usr/share/tomcat8/bin/bootstrap.jar:/usr/share/tomcat8/bin/tomcat-juli.jar
Server version: Apache Tomcat/8.0.38 (Ubuntu)
Server built: Mar 28 2017 23:47:32 UTC
Server number: 8.0.38.0
OS Name: Linux
OS Version: 4.9.15-x86_64-linode81
Architecture: amd64
JVM Version: 1.8.0_121-8u121-b13-4-b13
JVM Vendor: Oracle Corporation
Linode
Yes
No
Current emotional state:
A little sad due to above error. :frowning:
Tomcat Connector (defaults, I believe):
<Connector port="8080" protocol="HTTP/1.1"
		   connectionTimeout="20000"
		   redirectPort="8443" />
More Details:
Following guide: https://certbot.eff.org/#ubuntutyakkety-other
Added test.txt to .well-known and it is visible in my browser: http://anwinity.com/.well-known/test.txt
Accepted HTTP on port 80. Not accepting HTTPS on 443, yet. Port 80 is being forwarded to 8080. Port 443 is being forwarded to 8443.
As of right now, i can’t access http://anwinity.com/ either.
*   Trying 2600:3c01::f03c:91ff:fe56:2776...
* connect to 2600:3c01::f03c:91ff:fe56:2776 port 80 failed: Connection refused
*   Trying 192.155.82.200...
  0     0    0     0    0     0      0      0 --:--:--  0:00:01 --:--:--     0
... blah blah blah ...
  0     0    0     0    0     0      0      0 --:--:--  0:02:09 --:--:--     0
* connect to 192.155.82.200 port 80 failed: Connection timed out
* Failed to connect to anwinity.com port 80: Connection timed out
Are you sure your DNS records are correct, all the software is running and listening on the right IPs, a firewall isn’t interfering, etc?
Turns out it was the firewall. I think I set it up a little too aggressively. Looks like it succeeded! :slight_smile:
Thanks for the response! Hopefully no more problems…
