We'd need to know more about how you got your previous certs to suggest how to proceed.
You actually got a cert on Sept7 which is valid until Dec6. Although your ISS server isn't using it. The problem wasn't in acquiring the cert but something in your local server config. Your server has these response headers. Does that INxSQL system manage that?
This is the problem, we do not know who changed to this cert. the company we used to use. does not want to do this anymore. our site is down and it is costing us daily being down and everyone says they can't help because they don't know.
Well if you don't know how your server is set up, I'm not sure why you're expecting random strangers on an Internet forum here to know how your server is set up. There are some pretty smart people here who can do their best, and we can give general advice, but it's going to be hard to give specifics without knowing any, well, specifics.
The usual approach is that there's some software running on the server that manages certificate renewals and installation into wherever it needs to go. On a Windows server, that's most likely one of Certify the Web, win-acme, simple-acme, or Posh-ACME. If you can figure out what's installed and get to its logs, that will likely help explain what problem it's running into with managing the certificates.
I have access to the IIS server certificates, INX is the software we use that the site is built on and is the CRM. I have built the site and host the site in house, but I have never had to deal with this part. The last cert I was involved with was from Sectigo. We do not know who made a change over after question to everyone that works on the server
Others are better at Windows systems. I just offer this for further info
In the past 2 years you got:
Apr30 2025: Sectigo cert that expired May2026
Apr28 2026: Let's Encrypt cert (two of them actually) expiring Jul27
Jul8 2026: Let's Encrypt cert (that is currently in use) expired Oct6
Sep7 2026: Let's Encrypt cert renewed
In the IIS if I click on the last cert that expired, it give me an option for Create Cert Request, Create Domain Cert, or Enable auto Rebind of Renewed Cert
yes, the cert your IIS server is using was issued Jul8 and expired Oct6
But, a cert was issued on Sep7 that does not expire until Dec6. We know this by looking at the Public Certificate Transparency logs that show all publicly issued certs.
Your system is not using that one. You have either lost it or not properly applied it to your system. But one was issued. See the CertObserver link I provided in post #2
I have located the file on the server, no idea why it was never issued to the server. Who ever downloaded it and saved it put a password on it. I am dealing with this issue now
The way that Let's Encrypt is intended to work (and the rest of the CA industry is getting there too) is for an automated system to renew the cert and install it where needed. There shouldn't be any "downloading" or "saving" by a person. If your current process isn't automated, you might be better off ignoring whatever that existing file is and just installing Certify the Web on the server (or some other client) to handle everything for you.
Who's "they"? I thought Certify the Web had a free version. Or, if you're not averse to the command line, simple-acme is definitely free and integrates well with IIS.
If it was Certify The Web it would be pretty obvious because the start menu would have Certify The Web listed and there's usually a desktop shortcut, plus there would be a windows service running with Certify in the name.
My guess would be it's win-acme or simple-acme. Look in windows task scheduler for either as a clue.
As a quick fix:
Download Certify Certificate Manager on the server and install it.
click New Certificate, (set up your acme account with Let's Encrypt first time), choose your IIS site.
The domains should be auto populated if they are setup in your IIS site bindings, if they are not you should do that should be unless you have a special reason not to. If not, you can manually add domains to get a cert but your initial https binding update will need to be manual once you have your cert.
Request Certificate : certificate will be ordered from Let's Encrypt, renewal will be automatic.
That app is commercial, but evaluation is unlimited (no time or feature limits).
