Expiration notice for domain not due to expire?
rural.net.au
/usr/local/bin/certbot renew --pre-hook “apachectl graceful-stop” --post-hook “apachectl start”
Processing /usr/local/etc/letsencrypt/renewal/rural.net.au.conf
Cert not yet due for renewal
/usr/local/etc/letsencrypt/live/rural.net.au/fullchain.pem expires on 2019-03-05 (skipped)
No renewals were attempted.
No hooks were run.
Apache/2.4.35 (FreeBSD)
FreeBSD 11.2-RELEASE-p4
yes.
no.
Additional: the reason for posting is that I have just received an email from letsencrypt saying:
“Your certificate (or certificates) for the names listed below will expire in 20 days (on 25 Jan 19 04:54 +0000). Please make sure to renew your certificate before then, or visitors to your website will encounter errors.”
So my question is why am I getting the notice, when certbot is saying the domain isn’t due to renew?
Usually it means there is a different certificate with a different combination of subdomains. You might have replaced or deleted it, or it might be installed on a different server you forgot about or something.
In this case, there’s an older certificate for only the name rural.net.au, while your newer certificate is for both rural.net.au and www.rural.net.au.
https://crt.sh/?id=895024528
If you’re not using the other certificate for anything, you can just ignore the emails.
Ahh, that would make sense. I (mistakenly) thought that the new cert would have invalidated the old one.
Thanks for the prompt response!
