/etc/letsencrypt/live and /etc/letsencrypt/archive do not exist
My domain is: wanda.multivu.com (bogus domain, there isn't really such a domain)
sudo certbot --nginx certonly -d wanda.multivu.com -d www.wanda.multivu.com
Error while running nginx -c /etc/nginx/nginx.conf -t.
nginx: [emerg] BIO_new_file("/etc/letsencrypt/live/wanda.multivu.com/fullchain.pem") failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/etc/letsencrypt/live/wanda.multivu.com/fullchain.pem','r') error:2006D080:BIO routines:BIO_new_file:no such file)
nginx: configuration file /etc/nginx/nginx.conf test failed
Could not choose appropriate plugin: The nginx plugin is not working; there may be problems with your existing configuration.
The error was: MisconfigurationError('Error while running nginx -c /etc/nginx/nginx.conf -t.\n\nnginx: [emerg] BIO_new_file("/etc/letsencrypt/live/wanda.multivu.com/fullchain.pem") failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/etc/letsencrypt/live/wanda.multivu.com/fullchain.pem','r') error:2006D080:BIO routines:BIO_new_file:no such file)\nnginx: configuration file /etc/nginx/nginx.conf test failed\n',)
nginx version: nginx/1.14.0 (Ubuntu)
Ubuntu 18.04
None
No
No
certbot 0.31.0
In general, I just followed the following instructions to install internal wiki site:
Then,
nginx -t
failed because live folder was not found. I did not delete anything, I just followed the instructions.
  • sudo certbot certificates
    gives me:
    No certs found.
Hi @ogoren, and welcome to the LE community forum :slight_smile:
Did you read the first paragraph in your post?
That said, the problem you seem to be having is that your nginx config is trying to use a cert that hasn't yet been obtained [or somehow has been deleted].
Hard to say without a crystal ball. :crystal_ball:
Step #1: Fix the nginx configuration.
Step #2: Use the LE staging environment throughout the testing/troubleshooting of obtaining a cert.
Step #3: Use the LE production system to obtain a real cert.
Hi.
I gave my real domain, at least the one I asked for a cert for. As I try installing an internal wiki server, I'm starting to believe I do not need a certificate at all, as I will only use HTTP. Regardless, how do I reach the LE staging env, or the LE production system?
Thanks,
Ofer
*** 8.8.8.8 can't find wanda.multivu.com: Non-existent domain
*** 8.8.8.8 can't find www.wanda.multivu.com: Non-existent domain
Did you spell it correctly?
[did you register the domain name?]
Just add --dry-run to any certbot line.
sudo certbot --nginx certonly -d wanda.multivu.com -d www.wanda.multivu.com --dry-run
Hi.
This is an internal domain, for internal usage. I do not need this server to be accessed outside the local network. So the domain is not registered. I understand now this is wrong. I also understand I do not need HTTPS for my server access, so no certs are required. I will configure my conf file accordingly. Thank you.
multivu.com does exist but no wanda.multivu.com exist in any of the DNS Records for multivu.com
DNS Lookup - Check DNS Records
I do not see how any Domain Validation Certificate Authority could supply a Certificate for wanda.multivu.com
@rg305 has corrected my understanding below.
Not via HTTP authentication.
DNS authentication, however, can get names on certs that don't (yet) exist.
Oh, I didn't know that thanks for correcting my understanding. :slightly_smiling_face:
Think of the "wildcard" example...
There is no IP for "wildcard".example.com
[there isn't even an IP required for "_acme-challenge.example.com" - only a TXT record]
And yet, with DNS auth, we can issue such "wildcard" certs!
Yep, I get it. I hope showing my ignorance helps others also in learning as well. :slightly_smiling_face:
I too speak so that others might read and better understand - not (only) to lecture you - LOL
Of course, that command isn't using DNS authentication and would thus fail.
