I am using FPDF to generate pdf files on the fly from my website (see: CREATIVE | Float Glass Design for Architects and Textured and Creative Glass Applications). Application errors when trying to create the pdf from a contact form. I wonder if there is anything I can do to fix the problem. The vendor has told be to 'Just copy the image locally. It will prevent the SSL issue when retrieving
the file.' I wonder if the only solution is for the vendor to update their script for FPDF. Or should I use another SSL provider to solve the issue? or can I make a change on my server to workaround this issue.
regards
Hugh
