Buenas tardes, alguien me ayuda con el siguiente error.
Procedimiento de autorización fallido. isolucion.emserpa.gov.co (http-01): urn:ietf:params:acme:error:unauthorized :: El cliente carece de autorización suficiente :: xxxxxxxxxxx: Respuesta no válida de https://isolucion.emserpa.gov. co/.well-known/acme-challenge/_w8jM3fJlSA3kkqu1der3VtIsP7HU2RgpNR5n7RNZwM : 404
NOTAS IMPORTANTES:
Los siguientes errores fueron reportados por el servidor:
I don't think the below is causing your problem but it is still wrong. I don't think that VirtualHost is actually processing the request at all. But we need more info from you.
When you correct the port number shown by @rg305 you should also fix the ProxyPass and ProxyPassReverse statements. You should add a trailing slash to the second argument path.
If the first argument ends with a trailing /, the second argument should also end with a trailing /, and vice versa. Otherwise, the resulting requests to the backend may miss some needed slashes and do not deliver the expected results.
