I’m following these instructions to install Let’s Encrypt onto my Rock64 with 4gb ram.
When I try to perform this command
sudo certbot --authenticator webroot --installer nginx
I am receiving this error:
rock64@rock64:~$ sudo certbot --authenticator webroot --installer nginx
Error while running nginx -c /etc/nginx/nginx.conf -t.
nginx: [emerg] could not build server_names_hash, you should increase server_names_hash_bucket_size: 32
nginx: configuration file /etc/nginx/nginx.conf test failed
The nginx plugin is not working; there may be problems with your existing configuration.
The error was: MisconfigurationError(‘Error while running nginx -c /etc/nginx/nginx.conf -t.\n\nnginx: [emerg] could not build server_names_hash, you should increase server_names_hash_bucket_size: 32\nnginx: configuration file /etc/nginx/nginx.conf test failed\n’,)
I am unsure of how to resolve this. What should I be doing?
