ianm
April 11, 2019, 3:26pm
#1
shorthill.ingagedigital.com
certbot --authenticator standalone --installer apache -d shorthill.ingagedigital.com --pre-hook “systemctl stop httpd” --post-hook “systemctl start httpd”
Error while running apachectl -v.
apachectl: The “-v” option is not supported.
apache 2.4.39
Fedora 29
no
or certbot-auto --version
if you’re using Certbot):
0.31.0
This all worked before my last dnf check-update.
Seems to be a known issue…
Fedora 29
I installed Certbot with (certbot-auto, OS package manager, pip, etc):
OS package manager
Additionally: httpd-2.4.39
I ran this...
area: apache
I suppose, as a workaround you could use certonly
and install the certificate manually.
I just tried:
sudo certbot --apache certonly
and it failed with the same error message.
Sorry, my suggestion to use certonly
was directed at @ianm who was already using --authenticator standalone
etc. More specifically the workaround is to avoid using the apache plugin entirely, so you could use certbot certonly --webroot
for example and that should work.
Meanwhile, a new version of certbot has since been released which I believe should have a fix for this issue. Although I don’t know if the Fedora package has been updated yet.
system
closed
June 7, 2019, 12:17pm
#5
