AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
VirtualHost configuration:
*:80 ibfinance.sas.pro.dns-orange.fr (/etc/apache2/sites-enabled/ibfinance.conf:1)
ServerRoot: "/etc/apache2"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
Excellent! That's what I hoped to see.
Let me check something...
I know this might sound silly, but you are actually running certbot on the server for ibfinance.sas.pro.dns-orange.fr
, correct?
would you say if Im connected throught ibfinance.sas.pro.dns-orange.fr or if, after executed the command "sudo certbot --apache" I selected "ibfinance.sas.pro.dns-orange.fr". For the first case: no and the second case: yes
Let's try something:
sudo certbot certonly --webroot -w /home/minecraft_serveur_owner/Sites_Internet/www -d "ibfinance.sas.pro.dns-orange.fr" --dry-run
It returned it:
Account registered.
Simulating a certificate request for ibfinance.sas.pro.dns-orange.fr
http-01 challenge for ibfinance.sas.pro.dns-orange.fr
Using the webroot path /home/minecraft_serveur_owner/Sites_Internet/www for all unmatched domains.
- The dry run was successful.
That's what I thought.
Let's try this then:
sudo certbot certonly --apache -d "ibfinance.sas.pro.dns-orange.fr" --dry-run
Challenge failed for domain ibfinance.sas.pro.dns-orange.fr
Domain: ibfinance.sas.pro.dns-orange.fr
Detail: Invalid response from
http://ibfinance.sas.pro.dns-orange.fr/.well-known/acme-challenge/IZcs-_CbGzUUik_m2Bzupz345sEx8_AsaieuM0H_47c
[90.76.236.125]: "<!DOCTYPE HTML PUBLIC \"-//IETF//DTD HTML
2.0//EN\">\n<html><head>\n<title>403
Forbidden</title>\n</head><body>\n<h1>Forbidden</h1>\n<p"
Yep. It's the non-standard webroot.
Alrighty then...
sudo certbot -a webroot -w /home/minecraft_serveur_owner/Sites_Internet/www -d "ibfinance.sas.pro.dns-orange.fr" -i apache
Plugins selected: Authenticator webroot, Installer apache
Requesting a certificate for ibfinance.sas.pro.dns-orange.fr
Created an SSL vhost at /etc/apache2/sites-available/ibfinance-le-ssl.conf
Deploying Certificate to VirtualHost /etc/apache2/sites-available/ibfinance-le-ssl.conf
Enabling available site: /etc/apache2/sites-available/ibfinance-le-ssl.conf
Redirecting vhost in /etc/apache2/sites-enabled/ibfinance.conf to ssl vhost in /etc/apache2/sites-available/ibfinance-le-ssl.conf
Congratulations! You have successfully enabled
https://ibfinance.sas.pro.dns-orange.fr
/etc/letsencrypt/live/ibfinance.sas.pro.dns-orange.fr/fullchain.pem
/etc/letsencrypt/live/ibfinance.sas.pro.dns-orange.fr/privkey.pem
Your certificate will expire on 2021-04-27. To obtain a new or
tweaked version of this certificate in the future, simply run
certbot again with the "certonly" option. To non-interactively
renew *all* of your certificates, run "certbot renew"
Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
Thank you very much for have take the time to help me!
You're quite welcome!
You can test your renewals with this:
sudo certbot renew --dry-run
ok I will remember for it
You can do it now if you wish. It's just a test. Won't actually change anything. If it succeeds, you should be worry free when it autorenews in 60 days.
Yes, I tested it and it working great!
