Error setting up route53 certificate
Please post back when you have a solution.
No havent figured out the solution yet. Still reading documentations hoping to find a definition for those two different files. Will post it once found answer.
As of this writing I have searched on Google but there doesn't seem to be official definition for the functions of the two files mentioned, "chain.pem" and "fullchain.pem". So I experimented exchanging one for the other, and it doesn't appear to affect the website. So yes I think they are safe to be said interchangable.
As @rg305 said, this is a combination of cert.pem plus chain.pem in a single file. This is provided because different TLS server applications expect different combinations of these certificates for their respective configurations. For example, a web server may expect the fullchain.pem combination, while a mail server may sometimes expect the cert.pem and chain.pem to be provided separately.
There is no configuration or environment that I can think of that would actively use all four of the PEM files that Certbot creates.
Thanks for this clear and definitive tip!
Not with HTTP, indeed.
But your site works perfectly on port 443 using HTTPS.
Yes, this is the desirable result actually. Thx.
Welcome to the Let's Encrypt Community, Jinghui :slightly_smiling_face:
Why do you want your visitors to be shown an error with no http to https redirection?
Hi there. Thank you for your kind reminder. I'm actually still working on it. once I figure out some of the key concept I'll improve my website.
